Big_ern_101
- Joined
- Mar 19, 2023
- Posts
- 382
Looking to get some options on a simple shore power/battery maintainer options in my 2006 Econoline
Current setup is:
-2x AGM starter batteries
-1x 100ah Lithium house battery
-200 watts of solar on the roof
-250A single alternator
-Renogy 50A DC-DC charger (the one that does solar and alternator charging of house battery and allows the solar to float your starting battery once the house battery is charged)
-Renogy Shunt
-Noco Genius 10 Pro charger connected direct to house battery AFTER renogy charger.
-No need for inverter/120VAC when running off battery
-Loads on house battery are ARB fridge, Diesel Heater, Maxxair fan, USB chargers for phones, lights, etc. Pretty low load.
-Weekender rig, not full time.
Desired:
-Single 120VAC Wall plug.
-Unplug and go simplicity. No switches or cables to move
-Maintain lithium and starter batteries. Keep them topped up and ready to go
-Supply enough amps that if I am in a situation where I have 120VAC, I can run loads off shore power.
Issues:
-Genius 10 charger gets batteries topped up and shuts off. Kinda sucks.
-Can only connect Genius 10 to one of two batteries - house or starter.
-Could get a separate maintainer for starter batteries, but thats one more thing to headache with.
Best idea so far:
-Source a 24 VDC 5A power supply.
-Switch between the 24VDC 5A power supply and solar panels using a SPDT relay with the trigger being when the 24 VDC power supply is energized.
-Feed the 24 VDC 5A power supply into the solar input of the Renogy DC-DC Charger.
-Use the Renogy DC-DC charger to maintain both batteries, basically faking it into thinking solar is coming in even when vehicle is parked in the garage.
Thoughts? Suggestions? Alternate options? Am I a dummy?
Current setup is:
-Renogy Shunt
Desired:
Issues:
Best idea so far:
