BroncoHauler-SMB
...I made a storage box for it mounted under the rear shelf
Brilliant way to keep it accessible and keep it safe.
Greg - perhaps you can shed some light on the combining of panels of different wattage. I have read what I consider very informed information about the inefficiencies of combining panels of differing wattage. Say a 100 watt additional panel is added to a my 300 watt panel. I am of the understanding that the 300 watt panel will be restricted by the 100 watt panel and thus the system will be 200 watts not 400. Is this correct? Does it matter if they are hooked up in parallel or series?
The other question is the practice of adding a portable panel to an all ready installed fixed system This is where the panel leads from the portable panel are added to the PV-In terminals on the existing solar controller. What happens here and is it really different from the above? Thanks!
I have a Renogy 100 watt panel with
Renogy Wanderer -- 30A Advanced PWM controller i leave hooked up to the single house battery, while parked at the high camp in CO.
Thinking of getting a small BatteryMinder 5 watt unit to hook to the starter battery, as there is strong sun up there all morning.
Would this be in effect a parallel circuit config ?
Any one see a looming disaster in the works ?
Personally, I would see what could be done to get another (or two) 100 watt panels up on the roof.
Gar- I think the long term longevity, or lack thereof, of the flexible solar panels out on the market has been well documented over the years. I could be wrong but it looks like the panel you referenced is of similar design in that the solar cells themselves are flexible. Even if the cells are small rigid units mounted to a flexible panel, I would still be cautious of it holding up long term. The connections between each cell will be flexed when deploying and when putting away for storage, something that will no doubt put stress on those contact points.
I supplemented my roof mounted 137W Kyocera with one of the Renogy suitcase units, they are available with/without their own charge controller. It works great as a supplement to my mounted panel and gives me some flexibility to maximize my solar input.
Without controller
https://www.renogy.com/renogy-100-w...lline-foldable-solar-suitcase-w-o-controller/
With controller
https://www.renogy.com/renogy-100-watt-12-volt-monocrystalline-foldable-solar-suitcase/
It also looks like they have one with a waterproof controller
I added an external plug in that is connected to my charge controller
You shared you get lots of sun on the roof panel lots of the time. It is taking care of both batteries. No need for the 5w thing at all. Is there something else going on that is making you concerned about charging? Personally, I would see what could be done to get another (or two) 100 watt panels up on the roof.
Ider- I don't know from Blue Sea, it's a SurePower 1315-200 separator, but yes that is the set up. I think the rpm's are high enough, that's why i said the batteries are connected when running microwave, but will double-check that when have the chance.
I think i follow what you are saying here, but the ultimate aim remains to augment the power fed from the Renogy 100W through the house battery;
with a small, semi-portable solar system fed through the hood/starter battery, without disconnecting the Renogy controller.
Any ideas on that pipe dream ?
