Charliesmom-SMB
Thanks. Through whom did you purchase the cables?
So I stand by the data, Your booster supports Band 2,4,5,13,and 25 and the 5G version n2,n4,n5, n13, n25.
T mobile supports the standard bands 2, 4, 5, and 12, but has three bands outside of the standard
71, 41 and 25. Older boosters did not support Band 25, newer ones such as yours do.
For the record AT&T has band 41, that is not supported
Verizon is all in approved booster frequencies..
So my statement does not say that T mobile is not supported by booster, just certain bands , that they use
From the HiBoost FAQ page
I'm happy that you like your booster, and feel that it is useful for you. In general I would still hesitate to recommend a booster solution if asked.
I also like options and have a mobile modem that supports multiple SIM cards , so I can run T-Mobile and AT&T. The T-Mobile account is relatively new, so I probably might take the time to switch over from one to the other if I am not getting service before I connect to Starlink. I can probably look at my modem data and see what band it is picking up. At my house it is picking up Band 2 & N41 on T-Mobile at the moment.
I
Is your Starlink mini the version they are currently selling? Sorry mine isn't here until this weekend. I get the impression from the product description that it only needs one cable unless you are going to plug into the ethernet port on it... From what I recall older versions needed 2 cables, 1 for power, 1 to connect to the router that would be inside your camper... Those were the ones that had the motor that would point to the satelites on their own. (I believe Chrome / Vancity Vanlife youtuber has one of those...).My use of extension cables is based on the fact that, my unit is mounted on the roof the majority of the time. I can dismount if I choose and such would need to extend the cables. I did not use the cables or wall power unit that came with the Starlink. The details of my starlink install are in my build thread.
That pictured "boost adapter" is the one I am having delivered allegedly today. It is allegely sufficient to run the starlink dish off of the provided cable without using the inverter.I had purchased a 3-way adapter cable online with 12 V, USB-C, barrel connections but only the USB-C would work with the mini, plus the adaptor cable was only 10 ft long. After learning about the voltage drop from longer Starlink cables on this thread, I knew I needed a converter (thanks @Scalf77). Not wanting to hard wire a converter in the van, I purchased this 12V=> 36.8V "Boost Adapter" to connect my Starlink Mini to the van using either the house or my EB55 Bluetti battery.View attachment 1315332
I have attached a *.pdf table of the data from testing multiple connections from the Bluetti and house batteries.
In summary, the inverter worked very well, but as expected used 3X the wattage of 12 volt sources. The voltage from the house 12 volt connections without the booster did not meet the voltage requirements of the mini using a short (10ft) or long (30ft) cable. The USB-C connection on the Bluetti worked well for the mini with a voltage output of 19 volts. USB-C connectors in the van did not come anywhere near this voltage. Using the converter with either the Bluetti or house 12 volt plugs provided good Starlink connections with the short or long cables (36.8 V each).
The sale on the Starlink mini plus the 50Gig plan, and the ability to pause / unpause the account really sealed the deal for me.
Your use case sounds suspiciously like mine. I want / need cellular for contact and honestly sound en route, like anyone plays CDs in a vehicle anymore... so I am still trying to figure out the booster antenna situation and not coming to any good solutions yet... The plan is to only use Starlink when cellular won't cut it. At some point though, I am going to have to just bite the bullet and go with the unilimited service...This did it for me as well. Mine arrive overnight (!) and I used it this past weekend. I went from it being in the box to it being deployed and getting 200mbps in about 10 min. Super cool tech, and for me this basically solves all communication needs I have that my phone does not. I am opting not to mount mine as critical adjustment (like an inch or two movement) makes a very large difference in throughput. Besides, my use case for it is basically allowing me to work remotely if I need to, and I have to be stopped to do that anyway.
