Swivel Seat Base GRP BUY #7
Did you ever figure out what the “yaw” was for?
Have the same thing and just removed it but wondering exactly what to do now. :)
I think that yaw rate sensor ties into the traction control and could cause the check engine light to come on, but there should be a way around that. I just re seated it to not take the chance..
Thanks Darkstar. I posted on my other thread, but if this is what I think it is, based on some research around the web, then when it malfunctions (and possibly / probably if removed) the RSC / AdvanceTrak system goes haywire and will try and compensate for absolutely no reason when you're just driving down the road.
Doesn't sound like you've experienced that though, so a simple relocation hopefully is just fine. I did the same thing you showed on your post, with the block of wood cut out for the V plastic. Thank you for that!
Glad it helped.. I just got done putting in a Propex Propane heater ...that was a long time coming project.. always tense when you are drilling big holes in the floor... but copper line is run to propane quick connect on bumper all good!!
