arctictraveller
- Joined
- Mar 28, 2013
- Posts
- 4,387
Three photos, one the original Ford front rotor that was on the van when I bought it five years ago. The other two are new (5000mi) Powerstop slotted / drilled rotors with Powerstop supplied pads. The Powerstop rotors are trashed, but the original Fords are mirror like. The holes in the rotors are completely plugged, and the slots are almost level with the disc surface. Corrosion is the problem, the van only sat for a couple months while the rotors rusted away unknown to me. Oddly, today I was at the local autoparts buying more ATF and on the counter was a Powerstop rotor, the same exact rotor I have. Their machine shop had just turned it and the guy mentioned it was in bad shape when they got it, but didn't mention the exact problem. So, I suspect Powerstop is sourcing their castings in China with little to no Quality control on the metalurgy. When you look at the original rotors there is very little rust while the rears are completely corroded to the point of plugging the holes. More to come after I call powerstop (and Summit, where I bought them)
