The_Vermonster
I purchased a keypad off ebay, part number KB3Z-14A626-A. According to Ford and Tasca, this particular model is compatible with E-series vans from 07-15.
I can put the van into "keyless remote programming mode" and successfully pair my current two remotes. I can also successfully set a PIN on the wireless keypad. But I can not get the keypad to pair with the van. I have confirmed that both the remotes, and the keypad are transmitting at 315mhz. According to other instructions I should be able to pair the keypad by simply pressing the "9-0" button to lock.
I'm looking for anyone that has had success with this particular model keypad, or has a solution for similar struggles. I do have access to Forscan but I haven't see a way to manually add a "keyfob".
