A few comments......
*EDIT.....after writing all this I noticed that you are just lifting the very top of the ambo roof..........most everything below still applies except for spring loads.
That roof looks like it's quite a bit heavier than a SMB penthouse; consider sleeving the crossbars, they bend all the time on regular SMB vans. Use .750 OD x .083 (or maybe thicker) wall DOM (drawn over mandrel) Cro-mo tubing.
If you can't find the tubing locally McMaster sells it. search for 4130 tubing.
Now is the time to sleeve, as once you get the mech on the roof it goes from a 2 banana job to a 7-8 banana job.
Consider replacing the existing 1/4-20 crap pivot bolts with shoulder screws and saddle spacers; the pivot bolts break all the time too. Do a search here for posts by "Pete" to find the latest improved design.
The roof blocks 86Scotty is talking about retain the crossebars to the roof inside, the front one is simply a fixed ""pivot" for the crossbar to sit in and the rear block allows the crossbar to slide forward about 10" when the top is up. Make the allowable slide length a little longer than 10" so the top can go fully up.
Look at the rails where the rear crossbar is bolted to the slot and the chain, it's also about a 10" slot.
You will need to crank up the extension spring tension a lot based on the weight of the top. Do you have the rear compression "helper" springs? Are they 12" long or 24" long?
I would consider mocking up a 2x4 frame on the ground and fastening the scissor mech/rails to it and then place your roof on that to make sure everything is viable before cutting a hole.
In the stock SMB roof, the canvas is attached to the roof via small screws around the perimeter through the headliner. This means that if you want to remove the headliner to add solar roof wiring etc the canvas falls around your ankles.
The canvas is attached to the metal van roof using 1/4" thick x 2" wide plywood furring strips with a zillion sheet metal screws and butyl tape between the bottom of the canvas and the top of the roof. If your roof is flat use one layer of 1.5" wide butyl tape. The econoline roof has channels etc and there are places where you need up to 3 layers of butyl.
You can buy the butyl tape from McMaster-Carr.
I made similar furring strips to attach the canvas to the top and then installed the headliner over them. This accomplishes two things:
The canvas doesn't fall off when you need to get behind the headliner.
The zillion perimeter screws are all hidden by the headliner; in my van the headliner is held up by the crossbar ceiling blocks discussed above.
Check out the beginning of my build thread for some useful info:
https://www.sportsmobileforum.com/forums/f24/popping-my-top-10808.html
