Victron Smartshunt for sprinter start battery?
Vndlfsn
RV LIFE Pro
I’m really liking the victron smartshunt that I installed on the auxiliary battery. I’m thinking about adding one to the starting battery as well.
Is there a room in the battery compartment in the driver side floor to accommodate the smart shunt and the extra ground cable?
Or does the installation have to happen somewhere else?
You can get a voltage reading for your starter battery on your existing Smsrt Shunt. Just voltage though - use the Aux input port.
To put a dedicated one on your starter battery - keep in mind - the shunt is rated at 500A max, so the shunt has to be able handle the starter current draw. Also, it would have to go between the starter battery negative terminal and the negative cable so all the current is monitored.
Hopefully, Scalf77 or one of the other electrical guru's will chime in if you would actually get a proper current used/flow from a shunt connected to the starter battery.
This really isn't the best place to use a smartshunt as a battery monitor. Your cranking current may be larger then your shunt. Possibilities of conflicting current paths. Also hard to configure the smart shunt to actually know when it is 100%, lot's of opportunities for false completions.
It would be better suited to be used as a load or source shunt.
I generally just monitor the voltage. Take a week and write down what the starter voltage is after each day of no use. You should be able to get an idea on the daily voltage drop.
The conflicting current paths is what I was wondering about. I was thinking with an alternator providing current, loads can be handled without the current path ever going through the battery and shunt.
I bought a Victron 1000A Smart Shunt last year, it is quite a bit larger than the 500A unit. I may install it on our 5.4 van since the starter load will be well within that threshold. Really using it to see the parasitic loads while the engine is off. I might just install it temporarily to collect data.
If just using it as a battery monitor that is all you really want, the current going to and from the the start battery. For the most part that should look pretty uneventful. You would see a large amount of current used to crank the engine, and then a relatively large amount returned back once up and running. At some point that should tapper off to little or none going to the the battery, instead just being consumed by the other loads. It doesn't really take that long to replenish the starter.
Of course if your house charging loads are higher then what is available at say low idle, that would be interesting to see. As it should then consume power from the starter.
You could use the shunt configured to monitor the alternator output (source) and track that. I personally find that more interesting and useful. If you are also monitoring the amount going to your DC-to-DC or to your house battery , you could get an idea how much is going where.
The larger shunt would allow you to read the full current load, but of course is less accurate for lower current readings. It would be interesting data though.
My Transit has a SOC meter, I monitored it for about a month using Forscan (80% is considered full charge). I only have a couple of small loads that get used when the engine is running, so nothing really interesting for me to see. That and generally you only have access to that when the vehicle is running.
I don't use the Victron Connect phone apps very much, but I would think they give you a history of what the starter voltage is reading. ( I can get it using my Cerbo GX) I might check next time I'm out by the van.
