dogtubs
Advanced Member
Hello, I’m in the progress of ditching the AGM house battery located under the van. Have replaced it 3x since 2002, not bad battery life I guess. But jacking that beast down and up is a real chore. So, I’m installing a LiFePO4 in the “trunk” (a SMB addition) and running 4/0 wire to a new charger/inverter.
What I don’t understand is how the old AGM house battery was getting a charge off the alternator. The original 2/0 wires run from where the old AGM was located, through the frame, and to the old charger/inverter under the gaucho. Both are single wires.
I have a Blue Sea ML-ACR charging relay under the hood that has a terminal that connects to the house battery. Somewhere this wire must be connected to the positive lead on the old AGM under the van, but there’s only one positive lug under the van. This wire must be connected where I can’t see it - like in the frame somewhere? Anybody know where the house battery lead from the Blue Sea is connected to the positive 2/0 wire that connects to the old AGM battery? I can’t find it.
Thanks for any help!
