Old 11-07-2013, 08:47 AM   #11
Re: 4x4 conversion-expense vs. value
Have you seen this page? Its a complete how-to page on converting the OBS Ford vans, including which trucks to pick parts from. Have you considered doing the 4x4 conversion using pickup parts instead of parting out a running bus?
http://www.glinx.com/~sbest/4vanhow.htm
Old 11-07-2013, 10:52 AM   #12
rallypanam's Avatar
Here you go:
viewtopic.php?f=34&t=11029
Old 11-07-2013, 10:53 AM   #13
1reddog48's Avatar
I had not seen that site. Lots of good info. I think that this:
viewtopic.php?f=34&t=11029&p=114589#p114589
if it is 3/4 ton is the fast track to making the SMB 4x4.
All in all, I think the thing to do is submit to not having a SMB and re-do the CMB to suit my needs. I don't plan on any long distance trips in the CMB, so fuel economy is not a big issue.
Thanks for the info though, you never know what the next project may be....
I've never seen a trailer hitch on a hearse....
1reddog48 is offline   Reply With Quote
Old 11-07-2013, 10:59 AM   #14
1reddog48's Avatar
I did make an attempt to contact the seller of the 4x4 van parts, it does look like just what i need. We shall see if he replies. The insanity continues....
Old 11-09-2013, 12:19 PM   #15
I'd chip in with find another donor vehicle, now that you know the value of the chassis and what you're into. The SMB being really nice is a big part of that equation. Also if you're doing full donor salvage, wouldn't a F-series complete drivetrain be as good a starting point as a more rare 4x4 van?
Old 11-09-2013, 12:25 PM   #16
BajaSportsmobile's Avatar
I would say that a 2005 on up F250/350 front axle would be the easiest install to do. Almost all OEM parts can be used and the fab work is minimal - see QuadVan. If I didn't believe so strongly in the ride quality and long travel/low ride height of the Dana 50 TTB system that I am using then that is what I would be installing.
AgileOffRoad.com
Betsy
Dave&Di
2006 Ford E250
Lenny
