Old 03-21-2019, 12:18 PM   #1
crob0221's Avatar
Adios Control Arms
Anyone have recommendations for both upper and lower control arm replacements? My lowers both have snapped off and uppers arent looking great. The original channel style arms that came with the quigley conversion seem weak.
1999 E350 Quigley SMB
Cheers!
crob0221 is offline   Reply With Quote
Old 03-21-2019, 12:23 PM   #2
simplesez's Avatar
Quigley has replacements that improve the design. Keeps your geometry and they aren't expensive. Have your VIN when you call or email them. Not a tough project at all.
Old 03-21-2019, 03:49 PM   #3
MrHenrietta's Avatar
I had the same thing happen and upgraded to the newer round arms from Quigley. I also had to replace the brackets that the control arm hooks onto as they were worn out as well.
2003 7.3 UJOINT 4x4 SMB
MrHenrietta is offline   Reply With Quote
Old 03-21-2019, 09:34 PM   #4
Quigley has done some strange things. My arms on my 95 were early and they were boxed and never gave me any trouble at all. Then came this C design which didn't work.
Then tubes. Weird.
I agree with simplesez, just get the redesigned ones from them. I've never heard of them failing.
Old 03-25-2019, 05:44 PM   #5
Steve C's Avatar
Thanks everyone for bringing this up and providing answers on how to take care of it... As I was walking past my van today, I glanced at my control arms and sure enough I found an upper arm with a crack in it.
Steve C is offline   Reply With Quote
Old 03-26-2019, 06:23 PM   #6
Steve C's Avatar
Smile
Just ordered four new ones from Quigley, so I don't have to worry anymore. Current price(s) are $145 for uppers and $150 for lowers with 10% discount if you purchase four...
Old 04-01-2019, 07:40 AM   #7
Annie O's Avatar
What year are your Ford/ Quigleys that have the control arm failures?
2011 V10 E350 XLT SD Quigley/AOR (RIP'd)
Annie O is offline   Reply With Quote
Old 04-01-2019, 12:30 PM   #8
My opinion of Quigley going to C channel is so that the arm will flex (twist) easier than a tube version, which causes the weld to fail sooner. The axle swings on a center axis. The closer the upper and lower arms are the less they twist. Bushings can only flex so much. They are there for the dampening of the bumps and to allow minimal flex. A leaf axle has the benefit of allowing the leafs to twist and assist in the articulation of the axle. On a leaf axle the front and back bushing twist in unison to each other, unlike front arms twisting against each other. I do not believe the "Q" set up was really designed for excessive wheel travel hence the short arms. the best solution for the "Q" suspension is Heim joints at each end or at a minimum one end of each arm. Since I did my own conversion and do not have a "Q" set up or any other after market set up, I built 2"x.25 walled with inner 1.75 x.25 walled chrome moly tubing with 1.25" racing heim joints. The heim joints will hold the axle mount point and articulate at both the axle and at the frame mount. "Q" Factory replacement arms will only break again so all you are doing is kicking the can down the road. Good Heims are well close to $100.00 to 125.00 but it beats breaking in the boonies. To add I had a Jeep that I converted to the early Bronco radius arm style front Dana 44 axle. These are factory cast arms. After 10 years and 20 or so times thru the Hammers, I snapped those arms at the base of the arm where the C's mount to behind the axle. Yes both at the same time. The odd thing is if you are familiar with the radius arms they have a threaded end for a round (donut) style bushing at the frame mount so the arm can rotate/twist side to side like a pencil in a sharpener. The Jeep had 14" to 16"s of travel so when one side dropped in a hole and the other climbed, the axle needed to twist. The top side of the driver side wanted to roll forward and the passenger side back. Since those are 1/2'' wall axle tubes the C's were continually stressed. Even with the C bushings for cushion the years took their toll on the weakest point, the arms.
