Old 12-21-2022, 01:47 PM   #11
@E-350 Thanks. Good suggestion.
Scott
2019 Transit 350 HR Eco Quigley 4X4
“Vandemic”
Charliesmom is offline   Reply With Quote
Old 12-21-2022, 08:25 PM   #12
Originally Posted by E-350 View Post
I would put the new tire on the passenger rear so that you have “two new ones” on the rear.
Current rear passenger for me would be the new spare. Just check for damages ;-)
I agree, but the message I have entered is too short so I must lengthen my message to at least 10 characters.
Old 12-22-2022, 06:59 PM   #13
I had 15k miles on Goodyear Duratrac lt245/75r16 when I pulled into a discount tire a few weeks ago for an air check after a three day 2000 mile drive. The tech pulled over a manager and they pointed out sidewall defects on all 4 tires. They warranty replaced all four with bfg a/t in the same size they had in stock.
1998 E350 7.3 Hightop
r27d is offline   Reply With Quote
Old 12-23-2022, 08:13 AM   #14
You did a great job there!
Old 12-25-2022, 06:38 AM   #15
SheepShagger's Avatar
They only have a 2k load rating. Probably should never been put on your van in the first place. You may want to check the load rating on the new tires they put on.
Old 12-25-2022, 10:25 AM   #16
Per Goodyear they’re 3042lb rated.
https://www.goodyear.com/en-US/tires...ac/sizes-specs
Old 12-25-2022, 12:07 PM   #17
The "LT" got me so I looked them up and got that number, but yes the manufacturer has them as E rated / 3000lbs. Amazon has them as 2000lbs load rating
https://www.amazon.com/Goodyear-Wran.../dp/B07G7C15JV
Sorry for confusion.
