Old 04-30-2013, 10:15 AM   #21
Re: 2" wheel spacers, Pros & Cons
And I saw someone have a wheel work loose and go spinning off a trail near Silverton.
Point being that spacers add a point of failure. That may be acceptable in exchange for what you gain, but it doesn't sound like you need them.
And although they are sometimes hard to find in the right size, there's also the option of wheels with different offsets.
Old 05-01-2013, 07:40 AM   #22
Guitarvan's Avatar
Yeah, last thing I want is a bearing failure especially if I am out on the road or worse yet, off road.
Thanks guys
2006 E350 XLT, Ultra Wheels Rogue 175 16x8, Toyo Open Country A/T 265/75-16. MAXX Lift 2" leveling kit
Guitarvan is offline   Reply With Quote
Old 05-01-2013, 11:02 PM   #23
ANZAC's Avatar
If the offset is the same as what the spacer adds, you are creating the same leverage on the wheel bearings and the same risk. The spacers themselves don't fail, the bearings do from the extra leverage. Just to be clear.
Sportsmobile-less.
2007 Ford E-350
Stacy
At-At
Dirk/co
