Old 01-11-2019, 01:01 PM   #21
Orv
That is, believe it or not, the way that small non-structural cracks are dealt with on aircraft. Drill a hole at the end to eliminate the stress concentration from the sharp point, then if necessary attach a doubler plate.
I have a hunch this is due to the van body flexing while driving. I feel like getting in and out of the bunk wouldn't be enough stress cycles to propagate a crack that far, but I could be wrong. These bodies don't have a lot of stiffness in the roof area, and adding a penthouse top cuts out a lot of the reinforcing members. Westfalia conversions used to have a thick L-channel all the way around the opening for that reason (but those were unibodies, and so subject to more structural load.)
It could easily start at any rough edge or notch where the metal was cut.
N8SRE
Old 01-11-2019, 02:46 PM   #22
shenrie's Avatar
I was always told to drill holes for the corners and then cut to the holes. That way you don’t leave a weak point for a stressed area to start cracking from.
From the handful of pix posted on this forum of the cuts under smb installs I’m surprised we don’t see this more.
Old 09-03-2020, 03:08 PM   #23
vandiesel's Avatar
Originally Posted by John and Dana View Post
I am looking a repair this same issue only I live in Seattle and driving my van to Fresno and taking a week off work or shipping the van for a repair are not a feasible options.
I have had two plates made by a local fab shop that match the curvature of the van roof and will span from the buytl sealant to just shy of the rain gutter. My plan is to use a combination of 3M structural auto body adhesive and water proof pop rivets to secure the plates. The only thing I am not sure of is if the van roof is single of double wall construction. I remember reading the Ford vans had a double wall body which makes them stiffer but don't know if this only applies to the side or to both the roof an sides. It will make a difference in which pop rivets is order.
Does anyone see any potential pitfalls with my plan?
I appreciate any and all feedback.
Thanks
John
John, Reviving this thread. I have the same scenario as what you described. Did you ever perform this repair? Can you report on the outcome?
Old 09-17-2020, 02:10 PM   #24
John and Dana's Avatar
Orv, thank you for the poke, I meant to post an update to my repair but life got in the way. I am very happy with how easy the repair was to complete and how it turned out.
I had plates made by a local fab shop that were radiused to the contour of the van roof. They were not an exact match but close enough that I was able to pull them in place with the rivets. I painted the plates to match the van body before installing them.
I used a small die grinder and 3M abrasive pads to remove the paint down to bare metal. I drew an outline of the area the plates would cover and ground the paint off to within 1/4 inch of the edge of the plate. I wanted to be sure I didn't take paint past the plates to keep rust from forming.
I drilled small 1/8" holes at the ends of the cracks before installing plate to keep the cracks from continuing.
I used 3M 08115 auto body adhesive. This is used to adhere body panels and bumper panels and has a 3000 psi breaking strength. This is a 2 part epoxy and it requires a special applicator that mixes the parts as it is pressed out. I purchased both at a local auto body and paint supply store. The adhesive and applicator are also available on Amazon. There are aftermarket applicators which are cheaper than the 3M applicator but I wanted the project to go smoothly so I went with the 3M applicator.
I ordered 3/16 closed end rivets with a grip of .63-.125. I brought them through Hansen Rivets, www.hansonrivet.com. It is important to use closed end rivets to prevent water from leaking through the rivets. Most of the rivets you will find at local hardware store are open which could cause leaks.
I pre-drilled holes in the plates and two holes in the van body at the top corner of each plate to align the plates. I drilled the remaining holes as I installed rivets. This was because the plates didn't exactly match the curve of the van body and I wanted to avoid alignment problems.
I spread a generous amount of adhesive on the van body. I used a 1" plastic putty knife to evenly spread the adhesive over the area. This stuff is super sticky and you will need adhesive remover for the excess that comes out as you rivet the plate in place. There is a 3M adhesive remover specified on the package, which I didn't buy, but I found that Goo Gone did a great job of removing the excess.
Here are photos of the completed repair.
I am very happy with how the repair turned out and we have done some pretty tough 4x4 trails after the repair and there is no evidence of the cracks spreading.
I hope this helps anyone else trying to repair these cracks and am happy to answer any questions.
John
Old 09-17-2020, 03:24 PM   #25
pjpvi's Avatar
Nice! Do you want to do mine too?
What sheet metal did you use (Aluminum or Steel? Thickness?)? Maybe I'll tackle this one after I run out of other projects ...
Phil
- 2005 EB50 6.0PSD - SMB 4x4
