Old 12-03-2008, 12:27 PM   #1
Christopher Thwaites's Avatar
Jeeps
I'm looking for input from you jeep owners out there who flat tow..or not, your jeep wrangler.
Years to avoid?
Good years?
Models to avoid?
Good models?
4cyl-v-6cyl?
Auto-v-stick?
Must have options?
This will be a tow behind my van to a campsite and drive around the back country vehicle and a spare "town" driver. I'm not a rock crawler guy.
Thanks.
Chris/Ruth
2016 MBZ Sprinter 144" 4wd.
DIY
07 BMW 525xi wagon
Christopher Thwaites is offline   Reply With Quote
Old 12-03-2008, 12:46 PM   #2
John and Dana's Avatar
Chris,
I don't flat tow my Jeep but I can give you some input on other factors. I would suggest looking at a '97 or newer model. They went to a coil spring suspension in "97 and they are much nicer to drive than the older Jeeps. I have the 4.0L 6 cylinder and I can tell you that this motor is absolutely bullet proof. I have over 200K on mine and it still doesn't use a drop of oil between changes and I have never done anything to it other than change spark plugs. If you want to install oversize tires you will also want the 4.0. The biggest down side to the 4.0L is the mileage. It only get 15-17 mpg.
I have the manual trans and it is still going strong as well. I did have to replace the clutch at 180K.
I know lots of people flat tow the newer Jeeps, but I don't know if they have to make modifications to them.
Good Luck
John
John and Dana is offline   Reply With Quote
Old 12-03-2008, 12:59 PM   #3
Thanks...I have a couple of 98s and a 99 in sight.
Chris/Ruth
DIY
07 BMW 525xi wagon
