Old 11-01-2009, 05:53 PM   #1
2001 4x4 Sportsmobile 7.3 Diesel E350 EB
Power Stroke Diesel 7.3 Liter
77,5XX miles
Pictures (what everyone likes):
http://picasaweb.google.com/cyrusa153/SMB#
$47,000
-Sportsmobile/Quigley 4x4 Conversion
-Custom Cabinetry w/Aluminum doors, Yacht style push button entry, & Rhino lined cabinets, thoughtfully designed with price as no object
-Brazilian Cherry wood counter tops
-Front and rear Warn winches (12000Lb Front, 9000Lb removable receiver-style winch rear)
ARB Air differential lockers (both front and rear) w/ independent interior controls and dedicated compressor and PSI gauge
-Air Lift front and rear w/independent interior controls, dedicated compressor, tank and PSI gauge (Tank also provides access for tire inflation. Also comes with hoses + accessories)
-59 gallon diesel capacity (dual tanks)- Transfer Flow Fuel supply system w/Digital readout at dashboard indicating Front/Rear and combined totals
-Extreme custom Steel Bumpers front and rear, 3 pin receiver style 2” hitch (rear) with Hellas and 2 sets of fog lights in front and Reverse floods built into rear.
-Custom motorcycle carrier on 3 pin receiver hitch w/ Ramp (3 independent 2” receivers make the outside of the carrier as strong as the bumper so you can still haul a trailer, boat or whatever along with your bike)- this also works as the mount for the rear winch.
-Espar Airtronic D4 interior diesel heater with Thermostat
-Rhino lined front and rear Bumpers and lower vehicle body
-Wired for solar (plug-in point installed to rear of pop-top
-4 Deep cycle batteries (2 rear, 2 front)
-Engine Remote Start
-Remote Door locks
-Rear Camera
-Sportsmobile upgraded heavy-duty rear swaybar
-Hellwig upgraded heavy-duty front swaybar
-Upper and lower front control arms (tons of custom front end accessories)
-Grease zirc fittings throughout entire front suspension system (Maintained)
-2 piece wood platform bed makes a pod between rear cabinets w/custom cut 3” foam bedding piece (now stained Cherry to match the countertops)
-Cargo carrier + Ski/Snowboard accessory for Yakima rack
-Passenger captains chair w/built in swivel (pictured swiveled backwards)
-2 external air chucks (1 in front, 1 in center of chassy)
-Alpine DVD/ Navigation System and XM
-7 Focal speakers w/2 Amps crossovers etc.
-Focal 15” subwoofer installed in removable compartment in cabinet
-American Racing Teflon coated 20”wheels
-Toyo siped tires
-Vented front brake rotors
-Bilstein exterior reservoir shocks F+R
-Hi lift Jack on Front Bumper
-Extra Hi lift jack (Tall)
-Rear bench seat w/ seatbelts for 3 (Bench easily removable)
-10 gallon water tank for sink (plus rear compartment with opening for Another 30 gallon tank)
-Front and rear winch controls and accessories
-Electric lift Penthouse Top (windows,sreens, and zippers in perfect condition)w/ Fluorescent lighting front and rear
-2” memory foam pad for penthouse bed
-Dynamat sound deadening rubber insulation in walls
-Fiamma F45 Awning
-Focal 15” sub, 2 separate 3000 watt amplifiers, Phoenix Gold Powercore distributor + 8 more Focal speakers
-Blue Seal/Intelli Power 9100 12v Charging system w/Charge wizard
-Norcold AC/DC Fridge & Freezer (Large- and freezer freezes solid)
-Portable toilet
-Engine Block heater
-External oil pan heater
-Rocker switch (so you can adjoin all 4 batteries to jump front to rear or vice versa)
-Radio button (installed by Sportsmobile as a way to turn on vehicle front accessories (ie- stereo) w/o turning key on)
-Electric windows
-Tinted Windows
-Electric Locks (w/electric lock control built into rear door as well)
-Tilt steering wheel
-Air conditioning
-Cruise control
The actual Sportsmobile conversion was performed in 2005, the entire vehicle is in excellent condition and well-maintained. It is one loved and unique beast!
Vehicle is currently located in Jackson Hole, Wyoming
Thank you,
Scooter
303-588-7043
307-733-3182
beast of an 01 7.3 diesel 4x4 smb
play with it
cyrusa is offline   Reply With Quote
Old 11-01-2009, 06:03 PM   #2
Re: 2001 4x4 Sportsmobile 7.3 Diesel E350 EB
Nice rig, especially the countertops. Good luck with the sale.
Old 11-01-2009, 06:19 PM   #3
thanks herb- hate to see her go, but must liquidate any and everything for my motorcycle expedition: 2wheels7summits.com
play with it
Old 11-01-2009, 08:20 PM   #4
play with it
Old 11-01-2009, 08:22 PM   #5
More pics....
play with it
Old 11-01-2009, 08:23 PM   #6
and pics
play with it
Old 11-01-2009, 08:25 PM   #7
n pics
play with it
Old 11-01-2009, 08:38 PM   #8
Strangley enough, I have driven this van. It was for sale in Fruita, CO back in March. We test drove it the day before we ended up getting our SMB. This rig is tall, makes my SMB seem tiny! It drove very well and hey, it has the 7.3.
Desert Solitaire
2003 7.3L EB 4x4
Timberline 4x4 conversion
Old 11-30-2009, 04:56 PM   #9
my apologies to everyone who called/ emailed since i skipped town to play after posting this. i will be getting back with you shortly. yes, i am a screw off. thanks, scooter
play with it
Old 12-19-2009, 06:45 PM   #10
this amazing rig has been sold- many great years ahead for the new owner!
play with it
