These are designed for a van that has Reunell bumpers. They are BRAND NEW, never mounted, custom built by Mike at ExtremeFab.
Really high quality units. Left side for tire with 8 x 6.5 tire pattern. Right side is set up for a box install. (no box included but I can get you set up with one if you want one.)
Super heavy duty mounting plate attaches both on the top and on the vertical bumper surface. Mounting hardware is included.
PIVOTS: Heavy duty SEALED tapered upper and lower ball bearing swivels and Chromoly Trailer axle 1.5" 4031 Chromoly Steel Tapered shafts.
CLAMPS: Heavy duty DESTACO Pull Action Clamp latches
SWING LOCKS: Spring loaded swing out T Handle lock pins. These are really stout. Mounting pattern matches the stock Reunell mounting holes.
This is one matched set and I would like to keep them that way. Local pick up is the way to go, but I will consider shipping depending on effort and cost of packing. Seems like enough members running up and down the West Coast or through Reno, SLC and Denver that there might be a delivery option available that way, too.
Thinking $1,500 for the set
