Originally Posted by mikracer
I suspected the same as you but my thoughts were to disconnect the positive side of the battery.
NHRA requires you to have an exterior battery cutoff switch when trunk mounting your battery. I was thinking a battery cutoff accessible from the outside of the van might be a good idea in case something like this happens. Thoughts?
Disconnecting either cable stops separates power between the battery and the vehicle, the negative side is my go-to (especially in an emergency) because you can short the wrench between the negative post and the body, and have no effect. Short the positive side against the body with a wrench and you've made an arc welder, which is easier to do in a panic.
Related story: I almost forgot about this one; I once talked my daughters through disconnecting a battery during a small electrical fire, over cell phone, while they were on the side of the road. They were in a borrowed 1970 VW bug convertible, smoke was pouring out of the engine compartment. "hit it with the fire extinguisher, yank out the rear seat, grab a wrench and disconnect the battery, call me back after it's under control. Oh, have your sister grab as much stuff as she can out of the back seat in case it burns down, you go this now GO!" I told the oldest one. As a result of quick action, they saved the car before it got out of hand.
Yep, NHRA requires an external battery cutoff switch in cars w/relocated batteries, and all of the faster cars (I want to say 9.90 and quicker). Just about every other race organizations requires the same. Its a good tool for the safety/emergency crews. I could see that being helpful on a SMB. Those switches also go bad, and running more cables makes more failure points.
Originally Posted by daveb
the video makes me want to re-think about having a basic bug out bag that would be the first thing you grab
That's an excellent point, I have two, and carry one just behind the driver's seat on every trip, in my commuter car, I drag it with me on long trips even if we travel in someone else's car. It's becoming a habit to be the first thing I grab if there's some sort of minor emergency.
A tether for the dog is another great idea, I came a cross a rollover on Saline Valley Road last xmas. Bystanders said the couple took off running into the desert after their puppy... that could have really gone bad in several ways.
