Old 12-22-2017, 12:52 PM   #1
winmag4582001's Avatar
Aftermarket Aluminum Rim Torque?
So, all my life I've done 110lbs torque on aluminum and 140lbs torque on steel.
I usually don't let people make me question myself, but, a guy insisted that the aftermarket aluminum rims on my E350 van should be at 165lbs. Which sounds astronomically high considering we didn't even torque the rims on a 1586 International that tight on the farm.
What are you torqueing your aftermarket aluminum to?
My rims don't have steel inserts in the aluminum....
2017 Subaru Legacy
1990 Volvo 240GL
2x 1987 BMW 535is
1995 BMW 540i6
winmag4582001 is offline   Reply With Quote
Old 12-22-2017, 01:09 PM   #2
shenrie's Avatar
I've done 150 on 2 different sets of aluminum wheels since late 2012 when we got van. No isdues as of yet. None have even loosened a little bit that I could tell. Spec is listed as 165 iirc.
Old 12-22-2017, 01:14 PM   #3
1der's Avatar
I am at 145. I first torque to 120, then finish to 145.
Held up over fine for all the Baja abuse I gave them.
Old 12-22-2017, 01:23 PM   #4
Torque is based on stud size, not wheel material, unless you have an alloy wheel with a special lugnut, like Eagle uses.
Can can tell you with certainty my lugnuts won't stay on at only 110 ft-lbs.
Old 12-22-2017, 01:32 PM   #5
ShuttlePilot's Avatar
My studs are so rusty that it acts as natural lock tight and the wheel nuts would not back off even if only hand tight.
I tighten them up to the point I can get them off with the star wrench that's in the van, in traffic, at midnight, in the rain.
Which is about 140ft/lbs even though it calls for 165.
-Eric
2005 SMB RB 4x4 6.0 PSD
A rocket on the pad is safe,
Old 12-23-2017, 11:26 AM   #6
MSD
MSD's Avatar
I torque mine to 150, it's pretty much been the case at all tire shops I have used. But since I've put new wheels on, I do my own torque if I have anyone touch my wheels. I ended up having Les Schwab over torque and crack two of my rims and imbed lug nuts into all 4 of my former Weld wheels. In the end they had to buy me 5 new rims, but I still won't let them touch my van after that...
2003 Land Rover Disco II
1997 E350 7.3l 2wd - Sold
Old 01-12-2018, 12:20 PM   #7
When I did wheel repair the company policy was 100 on cars, and 125 on trucks for alloy.
NEIA Nomad is offline   Reply With Quote
KLUDR
vanderpooch
Clyde
ormtnbiker
