Old 05-21-2015, 08:00 PM   #1
outopawn's Avatar
Auxiliary fuel tank
I want to try and add this 40-gallon fuel tank that was taken from a 2004 f250 5.4L in my 2009 EB Quigley v10. The plan is to install it aft axle as an auxiliary tank. It still has the factory sender and pump and still mounted to a skid plate. I’m not quite sure how to go about this. Can I use the factory pump to transfer the fuel to the main tank? Any advice would be greatly appreciated.
Steve
2006 EB Transformer SMB 4x4 Diesel PH F/R Aluminess SOLD February 2015
2009 EB E350 V10 Quigley - Non-SMB
2005 4x4 Excursion 6.0 Diesel EB Magnaflow Superchip - Bulletproofed
outopawn is offline   Reply With Quote
Old 05-21-2015, 10:57 PM   #2
larrie's Avatar
Re: Auxiliary fuel tank
Our 89 Ford SMB has dual fuel tanks. One is in the center of the driver side and the other is centered behind the rear axel. There is a toggle switch at the bottom of the dash to the left of the steering wheel that is used to switch from the front to rear tank. When the switch position is changed the fuel guage shows the amount in the newly selected tank. I believe there is a pump in each tank. There is also what I will call a transfer control unit mounted on the frame. If I remember correctly the tank pumps into this unit and then to the engine.
You may be able to find all the necessary pieces in a junk yard. I know that the transfer control units are still available because we had to replace ours because it would only work with one tank.
Our two tanks hold about 35 gallons between the two of them.
Edit: there is a separate filler port for each tank, one on each side of the rear wheel.
Larrie
Old 05-22-2015, 03:07 AM   #3
schluchtenflitzer's Avatar
Hi Steve
here you can read how i did built an auxiliary tank and how i conect it. Maybe there are some ideas for you?
viewtopic.php?f=24&t=16079
www.Dieda-unterwegs.net
schluchtenflitzer is offline   Reply With Quote
2006 Ford E350
unreng
Babe
Babe
