Old 08-25-2015, 04:00 PM   #11
reelchef67's Avatar
Re: 27 series 6V agm's ! perfect for traverse vans
Originally Posted by daveb
OK, You know size does matter
Yup as my wife says , "nobody wants a small glass of wine"
2002 E250 5.4 4R70W 2wd 3.5 inch lift Pleasure-Way Traverse on 16x8 with 265/75/16's
reelchef67 is offline   Reply With Quote
Old 08-25-2015, 04:05 PM   #12
OK, I missed that.
Just wanted to clear that up for other members. You know size does matter
Don't also forget that performance is diminished when cold.
Old 08-25-2015, 04:14 PM   #13
reelchef67's Avatar
OK, I missed that.
Not so much for us with folks that hail from the land of the vikings...[emoji33]
Old 08-27-2015, 04:37 AM   #14
OK, I missed that.
Old 09-02-2015, 08:12 PM   #15
reelchef67's Avatar
Re: 27 series 6V agm's ! perfect for traverse vans **Update*
Batteries have settled in very nicely and sit at about 13.4 when van is turned off.
Turned on my fridge, furnace ,lights and plugged stuff into all mu=y usb ports and the voltage dropped to 13.1 and stayed. Fridge seemed to cool down quicker as well.
However the extra weight from going from one tiny 24 series agm to two 66 lbs 27 series agm's has added to my drooping backend. So I laid off the french fries..
And now I'm getting add a leaf to return it to proper height plus a 2 inch block and some Variable rate E350(moog CC880S) springs up front to pick up the front end a bit .
I told my wife its because of the North shore Bike rack she had me Get since SHE has taken up and mountain biking and now rides with me and we needed a "good rack" her words
Its all in the master plan
Old 09-02-2015, 08:50 PM   #16
I told my wife its because of the North shore Bike rack she had me Get since SHE has taken up mountain biking and now rides with me and we needed a "good rack" her words
Better hope your wife hasn't taken up reading this forum.......
Old 09-02-2015, 10:09 PM   #17
I just added a leaf to our EB build, as it was sitting more on the factory overloads than I wanted. Ended up using a SuperLift 2570 A-A-L that got me over 3 inches in the rear and improved the ride quality. More lift than I was expecting, but I can always remove the factory overloads to drop her back down a smidge.
Just Sunday added the CC880S and brought the front up just a bit over an inch. Improved the ride again, waiting to get an alignment, after things settle down a bit. All in all I met my goals, improve the ride after all the weight added by my build, and give me a bit more clearance for 265/75's.
Waterski02 is offline   Reply With Quote
Old 09-07-2015, 03:10 PM   #18
reelchef67's Avatar
Sounds great
