Old 04-20-2015, 10:27 AM   #1
Accessory terminal question
just had a trans cooler installed, which called for a "key on/accessory" connection with its own 20 amp fuse. guy who did install wired it into the main (engine bay) fuse box. There is also fuse panel inside near drivers foot well area.
which of these should be used in this case and why?
thanks,
carl
2010 SMB
Old 04-23-2015, 09:51 AM   #2
Re: Accessory terminal question
Reason for initially bringing this question up was that my local garage wired a trans/fan cooler into fuse #54 under the hood which on my truck was empty. Little known to the mechanic, (or myself) that location was still wired into the system and when the fan was actuated it caused the vehicle to not shut off despite removing the key!
After my own research with Ford, he should have gone to "accessory" location near drivers feet.
carl
2010 SMB
Betsy
darryldickie
Guster
Salmon
