Old 06-20-2012, 11:26 AM   #1
Gnarvan's Avatar
Cure for night blindness
I decided to get rid of the Hella 500FF fog lights and upgrade to something brighter. I may regret that decision on nights when there's fog. Foggy nights don't happen as much as regular night driving so I did the swap. I replaced the 500FF Fogs with Hella 4000ci HID internal ballast lights.
http://www.rallylights.com/detail.aspx?ID=4272
The HID's put out a heck of a lot more light and use 35% of the wattage of the 100W fogs.
Let there be LIGHT!
Side by side light comparison picture
Look at all the purdy red rings
John
Gnarvan 1992 E350 Clubwagon
2003 BMW R1150GS-Adventure
2013 BMW R1200GS-Adventure
Old 06-20-2012, 01:19 PM   #2
twogone's Avatar
Re: Cure for night blindness
'ja git the optional stone shield... at 5 large per I'd be too dang worried
They look like good gear! Available in black v red?
Keep us informed on performance, please
'95 SMB E350 Quigley 7.3
https://www.taylorarts.com
Old 06-20-2012, 02:15 PM   #3
BIGVANS's Avatar
Awesome!
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 06-20-2012, 02:49 PM   #4
Ultrasport12's Avatar
They look great...Don't catch anything on fire...
Did you replace all five?
Maybe you could have kept two of the fogs for side fill and for foggy and snowy nights.
...Jamie
2008 Ford E-350 V-10 EB
Transformer Interior
2004 F-350 Dana 60
Old 06-20-2012, 05:07 PM   #5
Gnarvan's Avatar
The $tone $hields are a no brainer. Yep, got em on all 5. Can't wait for the drive home tonight. I'll probably take the long way home on old Evergreen Hwy so I can dial in the aim.
I had the two fogs for fill in lights. They didn't work that well as fill in lights. The 3 big lights overpowered most of the light from the 500FF's. My plan is to aim the 2 4000ci's low and outside to get the side of the road. Then have the 3 4000's aimed straight down the middle a little higher for long distance coverage.
I'll try and get some night pictures posted soon.
John
Old 06-21-2012, 08:41 AM   #6
Nice lights- Are they a direct bolt-in? Can you install and remove the rock shields without removing the lights?
Bill
NO2B
Old 06-21-2012, 09:11 AM   #7
Gnarvan's Avatar
The lights bolt to the bumper via a 10 mm bolt on the bottom of the light. Hella offers a locking nut gizmo which makes them hard to steal. They call the anti theft thing a tuff nut. The Rallye 4000i Hid and the Rallye 4000i compact HID are Hellas's top of the line off road race light. They are super stout and easy to adjust. The ballast is built inside the light so you don't need to mount it separately.
http://www.rallylights.com/detail.aspx?ID=3695
The stone shields do pop on and off. I haven't tried to remove the shield on the smaller 4000ci's while they are installed in the bumper holes but it should be manageable. The glass on the lens and the inside of the shields need to be cleaned once in a while so you don't loose any light due to dirt blocking the lens.
I did stop last night on the way home from work and got some pictures of the beam patterns. I'll post them latter this morning once the caffeine kicks in.
John
Old 06-21-2012, 09:15 AM   #8
I had the stone shields mounted on my Hellas. Just be careful not to turn the lights on when your rig is not moving for a length of time. I once accidentally turned on the Hellas in the bumper, and when someone let me know about it maybe 30 minutes later, the built up heat between the Hella and the stone shield had lightly scorched the stone shield.
Old 06-21-2012, 10:29 AM   #9
Gnarvan's Avatar
Beam patterns of Hella lights on the front of Gnarvan
I have replaced the stock headlights with Hella 200MM Rectangular E-code Hi-Lo conversion headlamps with a 100W high beam and a 55W lowbeam bulb
Hella E-code conversion headlamps
http://www.rallylights.com/detail.aspx?ID=744
Hella 4000i Compact HID lights 6.69" diameter
Hella 4000i HID lights 8.75" diameter
http://www.rallylights.com/detail.aspx?ID=4271
The pictures were taken with the front of the van 14' away from a wall. There was a slight grade up to the wall. My left headlight needs to be adjusted down just a smidge. It also looks like I can seperate the beam on the 3 4000i lights a little. It looks like there is to much overlap. I may also be able to lower the 4000i compacts a little so they are just a little under the bigger lights. This should improve the coverage a little over the current adjustment.
Hella E-code low beam pattern
Hella E-code high beam pattern
Hella 4000i Compact HID pattern
Hella 4000i HID pattern
Hella 4000i HID and Hella 4000i compact HID pattern
On road low beam only...the ring of light you see on the right side is from the camera flash
On road high beam....the ring of light you see on the right side is from the camera flash
On road high beams and both sets of HID's
John
Old 06-21-2012, 08:35 PM   #10
Dango's Avatar
Not bright enough. You need 4 more up top. Holy s--t Batman.
Dango is offline   Reply With Quote
Big Backpack
RMAC
ClifFord
EliMakes
