ScanGauge
I have a ScanGauge II and none of the XGauge functions work when I program them in, ie TFT, CHT,etc. After numerous times of programming, Linear Logic sending me another unit programed by James (their tech) it still does not work. All the normal readings work, RPM, Voltage, MPG, MPH, and so forth work just fine. The tech thinks that Ford has changed where they store the information in the PCM and has not published this info yet. So my question is, "How many 2009 or later Ford E350 Sportsmobile owners out there have a ScanGauge II and do they work with the XGauge Programs?". I have a PCM Code of X Y S 0. If you have one that works, what did you do to make it accept the programming?
Jim P
