Old 04-24-2012, 09:09 AM   #1
Will the Yamaha 2400 gen run my Starcool A/C?
I'm looking at getting a portable gen, trying to decide on 2-2000's or one 2400 watt Yamaha. The 2400 is cheaper that 2 -2000's, but will a 2400 one run my Starcool A/C? My van is an 04' Ford that wasn't converted until mid-2005. What is the wattage draw of the A/C?
ehc0720 is offline   Reply With Quote
Old 04-24-2012, 03:23 PM   #2
Re: Will the Yamaha 2400 gen run my Starcool A/C?
I believe you'll need a 3000 watt to run it safely. If I recall 2800 was the limit but SMB suggests 3000 to cover the start up load.
Old 04-24-2012, 04:36 PM   #3
I might be parting with my very low hours 2400
bought it for my polar cub
only used it twice......
bw
pm me
i am in south orange county califorinia
Old 04-24-2012, 06:04 PM   #4
BIGVANS's Avatar
Use a 3000w minimum because the “Startup” draw of the A/C (condenser) is higher than the running draw and low voltage can damage your A/C unit.
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 04-24-2012, 10:29 PM   #5
Thanks all, I guess the 2400 won't do. Now another question, can these generators be carried inside the van without special venting? I assume there would be gas fumes and maybe left over exhaust fumes. Should I get a hitch carrier/box for the generator and gas can?
Old 04-25-2012, 12:20 AM   #6
Mine had a cap/vent that shut off but like any engine some smell will be around. Kind of up to you.
