Originally Posted by 86Scotty
... Obviously you can skip good old heavy laminate residential countertop. I used that on my last van but it is thick and heavy and I don't think it's the ideal choice for an RV. It is easy to find and use though and looks pretty good.
Thoughts?
Not sure why you say laminate is thick and heavy. The stuff I used, Wilsonart, is about 1/16" thick. It's glued onto 3/4" birch plywood and then has a rubber edge band. I think it is probably the best ratio of cost to utility. Maybe you're thinking of a pre-made laminate countertop, which is made with chip board?
