Duct board as insulation?
I have a 15 pass 2wd e350. Trying to figure out best insulation to use. I'm thinking about using duct board glued to the back side of the finish panels, foil side out. May have to leave some voids at the ribs, etc. Was thinking of reflectix glued to the ext walls with fiberglass mats in between but the radiant needs airspace to work right, correct? Maybe reflectix on ext, then duct board
on panels. Talk me into something different if you have better ideas. What about rigid foil faced urethane foam on the floor? Will that need plywood over the top? Also thinking of cutting flow from rear heater core, I think it is always hot. I live in south Texas so keeping the cold in and heat out
is the focus.
