Old 03-05-2017, 05:29 PM   #11
joefromsf's Avatar
Plywood is 1/2" baltic birch......old 3/4" plywood ripped into furring strips and adhered to plywood using liquid nails.
Butyl sticky backed window flashing cut into strips and applied to furring strips to eliminate noise/squeaks.
Felt/rag carpet pad stapled to underside of floor to keep insulation off of metal van floor.
Furring strips interrupted to allow wiring to run under the floor.
Flooring is called Nautilex "decko-dot" boat deck flooring. Most of the inside of the van and door panels are covered with the same stuff using contact cement. Door panel shown to illustrate texture of decko-dots.
Hey Boywonder,
You mention, "Felt/rag carpet pad stapled to underside of floor to keep insulation off of metal van floor.", but I don't see what type insulation you are talking about. Do you just mean the wood layers?
Any sound deadening attributes of your system?
--Joe
2012 E350 RB XLT Wagon, Agile 4x4, SMB penthouse
joefromsf is offline   Reply With Quote
Old 03-07-2017, 11:48 AM   #12
PNWVAN's Avatar
Here is what I have as temporary flooring at the moment. 1/2 foam board and 1/4 OSB. Feels pretty solid at the moment, going to give it a go a trip we have coming up at the end of the month. Put Reflectix behind the stock wall panels until can do more permanent walls. Will know how much it helps after the trip.
PNWVAN is offline   Reply With Quote
Old 03-28-2017, 09:20 PM   #13
IrishAl's Avatar
How did you cut the OSB board to fit? Did you use a template?
IrishAl is offline   Reply With Quote
Old 03-29-2017, 08:22 AM   #14
PNWVAN's Avatar
IrishAl,
I bought a roll of brown masking paper and used that to make a template. It worked pretty well.
Old 04-24-2021, 08:34 AM   #15
Originally Posted by Annie O View Post
I know people have used various less expensive flooring options and are happy, but I saw a VW van last summer with flooring I liked and it was ALTROtransfloor.com
The rep explained the transportation line of flooring is built to flex and bend with a vehicle and some will hold up under heavy carts being moved on them. I suppose it depends on how your vehicle is used.
I think I priced it around $200+ shipping (from Cali) for my RB E350, starting behind from seats. Maybe they have end lots available at the factory.
Thinking of using a VanRug liner for base. I know it can be done cheaper but I'm finding I don't have much time to get interior where I want it- don't have a place to do it all myself.
It's Altro Transflor: https://www.altrofloors.com/Floors/T...oring-products
Bob
2002 Itasca 35U Motorhome
BCam is offline   Reply With Quote
Old 04-24-2021, 09:00 AM   #16
Originally Posted by BCam View Post
That stuff is awesome. Bus floor traffic is brutal and this stuff is warrantied for 15 years? I think that just went way up my list for my next build.
Is it hard to come by in small quantities?
Old 04-24-2021, 11:19 AM   #17
I have no first hand knowledge, but I did some Googling that may help:
https://www.fordtransitusaforum.com/...or-wood.75246/
I'm pretty sure you're going to have to contact the manufacturer directly to get details including local vendors.
Bob
Tags
flooring insualtion floor
