carringb: Yes, I see the Daily is body-on-frame and tows 7,716 lbs. Not alot compared to a dually E350, but probably enough for a SMB towing a boat or other trailer packed with recreational gear. And it is rear wheel drive unlike the front wheel drive Sprinter and is available in 4x4. Unfortunately, no Iveco's are imported into the US or Canada.
"Daily Range
The Daily drives like a car, yet is built on a solid steel truck chassis. It offers a superior turning circle, up to 40,000 km engine oil service intervals and up to 3,500 kg towing capacity. The Daily offers a wide range of engines, wheelbases, load volumes, carrying capacities and axle ratios. There is a choice of two gearboxes: the 6-speed manual and the AGile™ automated 6-speed.
The Daily range includes:
•Van
•Cab Chassis
•Dual Cab"
http://www.iveco.com.au/index.php/on-ro ... ight/range
FYI, here is the Daily van:
http://www.iveco.com.au/index.php/on-ro ... /range/van
"Daily 4 x 4 Range
The Daily 4 x 4 offers the best combination of payload and off-road performance in the toughest conditions. Built on a solid steel truck chassis, it comes with permanent all wheel drive with three available differential locks (front, rear, and central), 24 forward and 4 reverse gear ratios. There is also the option of selecting the first synchronised reduction (half speed) with the vehicle in motion. The Daily 4 x 4 is also fitted with parabolic suspension with a live front axle to cushion the shocks of road surfaces.
Thanks to its design, the Daily 4 x 4 guarantees the performance of a true off-road vehicle with a:
•51° departure angle
•27° approach angle
•36° departure angle, with rear bar raised
•fording depth up to 700 mm."
http://www.iveco.com.au/index.php/off-road/daily-4x4
Looks like the Aussie's may have had a hand in the engineering or production of the Daily 4x4. Any experience with it by you downunders?
