Old 04-17-2015, 06:21 AM   #21
Re: Here I go
Originally Posted by bkbroiler00
Originally Posted by Wbp
Picked a set of middle row Sienna chairs now got to figure out how I will mount them.
it might be an Expo thread, but there's a dude that makes seat bases for Sienna to Econline. mgmetalworks i think is his handle. check it out, seems like a popular mod. and well worth it. good luck with the build.
MG is here too. Ujoint has the bases he makes if you want to find them closer. Ujoint is in Asheville, NC.
Old 04-17-2015, 06:32 AM   #22
Wbp
Re: Here I go
Thanks for the info I didn't get those really nice Sennia seats I got an older set and picked some removalable swivel bases and came up with a mounting setup that worked out great. Will posted some pic later
Wbp is offline   Reply With Quote
Old 05-10-2015, 04:59 AM   #23
Wbp
Re: Here I go
Got a few things done but had to take a break to work on the house.
Installed two chairs with removable swivel bases, seat belts and added swivel bases to front chairs? Steering stabilizer, spacers, and rear Hellwig sway bar.
Yakima roof rack with 54" tracks may had more track for front.
Maxxair roof vent
Next I am going to start putting together the electrical system and figuring out what and where thing will go. I got two factory battery boxes to mount under frame planning on two AGM batteries not planning on a lot accessories lights, outlets to charge things, 12volt frig? Freshwater system, fans. I am thinking of an inverter/charger to run a small microwave and dockside power inlet.
Old 05-10-2015, 05:02 AM   #24
Wbp
Re: Here I go
More pictures
Old 05-31-2015, 06:09 PM   #25
Gatorbait's Avatar
Re: Here I go
Nice build! Do you know if you can position the window at any height or does it have to go dead center?
And of course, GO GATORS!!
Gatorbait is offline   Reply With Quote
Old 05-31-2015, 07:26 PM   #26
Wbp
Re: Here I go
Hey Gatorbait I just saw you topic and found you here. Go Gators. As for the window placement on mine you can see I center mine and when you look on the inside their is roof frame structure up top. I can take a picture from the inside I have not closed it up yet. This may help you in placement.
I will keep,an eye for you on the coast during hurricane season.
Agnes
ranchero
Miss Piggy
graybeard
