07-16-2015, 01:13 PM
#51
Re: Meet Jupiter- a Homebrew thread
Originally Posted by shenrie
really great pix, but you left out the part about the van on the wrecker....
Oops hit submit, instead of preview.... I wasn't done yet, and you were too fast on the rebound.... now it's there. Thanks for reading.
1995 Econoline E-150 Custom Campmobile "Jupiter I" RB, 4wd Dana 60s, 93 Eurovan poptop.
1976 VW Type II Transporter Westfalia Campmobile.
1994 Toyota 4Runner,2001 Ford Escape,1970 Chevy El Camino,2 Cargo Trailers, 5 bikes, 4 Kayaks, 1 Canoe
07-16-2015, 01:14 PM
#52
Fuel pumps seem be on a bad roll lately.
That couldn't have been a fun/inexpensive tow. Glad you made the best of it.
07-16-2015, 01:21 PM
#53
Yeah, $400 for the tow, and $300 for the pump. And me over a barrel. Kristi and I split the cost... so it took away some of the sting.
07-16-2015, 05:21 PM
#54
Damn, you too? What is that area, the Bermuda triangle? I just lost mine a couple of weeks ago between Kayenta and Page, and spent a good bit of my vacation, and about the same money, getting ours fixed in Page. Sheesh, sorry to hear of your troubles! I'll tell more about mine in a TR I'm compiling. Excellent pics.
07-29-2015, 12:21 PM
#55
New Door Trim Panels
07-29-2015, 03:30 PM
#56
New Front Spring Set
You may recall in some earlier posts about the 4wd conversion that the front spring set-up was really unconventional. It was set up much like a Jeep, where the rear spring mount was a bracket welded to the frame, and the front was a shackle. The Jeeps use an 'H' style bracket bolted to the frame in the front. My conversion was SKETCHY. They welded a small mount/pivot to the frame and bolted in a strange shackle thingy. If there were ever an accident, or a wear issue this mount would surely be the weak point in the link, and no parts available to repair....
Nobody I've spoken to has even seen a set up quite like this, although it was perfectly functional. Functional, but not serviceable. It also had an annoying pull to the right. Not bad, but not good either. After an alignment I found out why. There was too much castor on the right side, that could not be adjusted, except by new springs.
I contacted Chris at U-joint, to inquire about his kit. Although it would work on my chassis, it would not work on my 86-91 Dana 60 king-pin style axle due to the spring pad position, welded to the housing. I would have to get a newer style axle, with all the trimmings.... Cha Ching!
Good thing I have a guy. He custom made the front spring perch, had new springs custom made, and put in new Bilstein 5100 shocks. It took a little while but it came out better than I had expected. You can see his cardboard mock-up below.
And the finished product (sorry for the iPhone pics)
Bye bye crumple zones
I love the smell of new Bilsteins in the morning...
Due to a ride height and side sway issue in the rear I installed some new air helper springs. No more saggy butt...
Now were riding smooooooth.... time for another trip!
07-29-2015, 05:37 PM
#57
08-01-2015, 11:52 PM
#58
Am I understanding correctly that there is no shackle at all on the front leaf springs now?
08-02-2015, 07:54 PM
#59
The rear bracket was torched off and a custom shackle was made for the back. Sorry for the confusion.
The frame takes a turn there however, and in order for the spring to be square, there was a spacer made to offset the bushing, as you can see in the above photo. The ride would be extremely rough if there were no shackle.
08-02-2015, 11:18 PM
#60
Ah makes a lot more sense now. I thought all they did was remove the front shackle and replace it with a solid bracket. Didn't realize they did added the shackle in the rear as well. I knew it'd be a terrible ride with no shackle but I didn't see it in there and I was wondering how they achieved such magical goodness with no shackle
