Old 11-01-2015, 04:24 AM   #11
Re: '08 5.4 transmission fluid leak
Double check your owners manual for proper ATF designation but I do believe Mercon V is the only acceptable fluid for that year.
Brand wise choose a good quality----I actually found Motorcraft at my dealer for just about $2 less per quart than anywhere else I checked----I was stunned and of course pleasantly surprised.
Castrol would also be a good choice if its available in Germany.
Old 11-01-2015, 09:01 AM   #12
chetubi's Avatar
Thank You.
I chose this one
http://www.ravenol.de/produkte/verwe...-mercon-v.html
Which seems to be approved by Ford
http://www.ravenol.ge/index.php?lang=en&id=26
For the moment it is just to refill some liters before the problrm is fixed.
'08 Ford e350 Sportsmobile
'07 Toyota FJ Cruiser
'10 Lada Niva
'04 Nissan 350Z
'67 Alfa Romeo Giulia
chetubi is offline   Reply With Quote
Old 11-01-2015, 10:19 AM   #13
I surprised you lost enough through that leak to show on the dipstick.
Also just to be sure; you are checking the level with the engine running in Park, but after shifting through each gear for about 10 seconds?
Old 11-01-2015, 10:39 AM   #14
chetubi's Avatar
Well. Probably it is leaking since I changed the radiator in SLC in december 2014. Then conversion took place and the shipping to germany.
Yes. Checked it with engine warm and running. Going through gears. Just not for 10s ...!?
'10 Lada Niva
'04 Nissan 350Z
Old 11-01-2015, 11:27 AM   #15
Only needed to hold it in each gear if you just started it up and its cold. If its warm, then it doesn't really matter, since each fluid path pressurizes immediately when its warm.
Le Moose
Stanvan
Campervan
Joerg
