Old 11-29-2017, 06:30 PM   #21
MountainBikeRoamer's Avatar
Having to modify the fuel tank to make room for the transfer case:
Do not like
This tank modification also ends up surrendering some of the fuel-tank's total capacity, too....does it not?
The range on one fuel tank is already short enough as it is....what with ol' Thirsty's big 10-11mpg appetite for the dino-juice. Hate to give up some of that range in exchange for the occasional need for a low climbing gear.
Mike T
___________________
'95 Ford E250 RB30 PH
Old 11-29-2017, 07:33 PM   #22
Would a passenger drop transfer case work without tank modifications?
TeleSteve is offline   Reply With Quote
Old 11-29-2017, 09:43 PM   #23
Bbasso's Avatar
A shortened fuel tank looses aprox 3-5 gallons fyi.
Or get the full replacement which holds 35 gallons and fits the 271, that I mentioned earlier .
Rob.
Current:
And had three other E350s...
Old 11-30-2017, 01:39 PM   #24
JackTuppVan's Avatar
I am posting this for additional reading on the subject of planetary over/under drive units.
I'm not suggesting this as a possible solution.
The HONE-O-DRIVE is and axle mounted planetary over drive.
I actually had a hone-o-drive unit in a 1970 cougar years ago , if I had only know how rare / expensive it was I would have kept it .
Apparently they are reproducing them.
it works on the same principal as carringb describes.
That all said... One workaround for a lack of off-the-shelf under-drives, is to go ahead with the Overdrive, combined with much lower gears. You'll get lower overall ratio needed for off-road driving, but still retain a reasonable top final-driving ratio for highway cruising.
http://hone-o-
drive.com/hone-o-drive/
2007 E250 Super Duty cargo
1988 Toyota Van 4x4 5-spd
Old 01-23-2018, 07:09 AM   #25
TomsBeast's Avatar
For a little more fun reading on the subject:
Here's a machinist that built his own doubler box, a "Klune-clone" using a planetary gearset scrounged from a New Process 231 transfer gearcase. This one bolts between his automatic transmission and his transfer gearcase. Great pics.
homemade Klune v style doubler - Pirate4x4.Com : 4x4 and Off-Road Forum
