Old 01-05-2021, 06:00 AM   #1
Axle codes
Does anyone know what the axle code would be for a 2004 - 2006 E150 with a 9.75" 3.55 LSD? Assuming that is a valid rear axle for that year E150.
Vanguy is offline   Reply With Quote
Old 01-05-2021, 06:05 AM   #2
I have a 2000 E150 that has a 9.75" 3.55 LSD rear axle that has drum brakes. I'm looking for the same axle but with disc brakes. The axle code in the door sticker is H9 which would indicate an 8.8 rear axle so that's not much help to me.
Old 01-06-2021, 12:41 AM   #3
neatvan's Avatar
This table shows you should look for a C9 axle code. And it also shows the H9 which matches your van. Don't remember where I got the table, but I keep it in my OneNote for van stuff.
neatvan is offline   Reply With Quote
Old 01-06-2021, 12:43 AM   #4
neatvan's Avatar
Not sure why that resolution is so terrible! I uploaded 2 different ways and still bad, but I think the last one is readable!
2005 Quigley E350 EB V10, Fiberine Super Camper Top
2006 Quigley E350 EB 5.4, Fiberine Super Camper Top (sold)
1995 4x4 Chevy G30 Extended 6.5l NA diesel (sold)
1984 Dodge B250 Get-Away-Van camper conversion (sold)
Old 01-06-2021, 04:37 AM   #5
Isn't the dana used on the 08 - 14 E150? Is that the same as the 9.75" on the 2004 - 2006 models? Looking for a 5 lug axle.
Old 01-06-2021, 01:03 PM   #6
Why don't you just convert your axle to disc brakes?
https://www.tsmmfg.net/ford-f150-bro...-kit-2530.html
There others that are cheaper them this one, just an example.
Old 01-07-2021, 05:44 AM   #7
I'm looking at that option as well. If I can find a salvage rear axle with disc brakes on it for a decent price it would be a perfect opportunity to go through everything and end up with a completely fresh rear axle assembly. Could also be an opportunity to change gearing from the current 3.55 to possibly a 3.73 or 4.10.
Interesting side note: I asked about doing a brake upgrade in another sub forum and got a reply about just doing an axle swap. I ask about axle codes here to do an axle swap and got replies about just doing a brake upgrade. Not trying to say anything negative just laughing at the irony. I do appreciate any replies that provide solid info or provoke thought from a different perspective.
