Old 10-14-2009, 08:59 AM   #11
UJOINT's Avatar
Re: Differential as rear jack point?
Originally Posted by j.whitbread
Originally Posted by UJOINT
Originally Posted by Stumpalump
I do it on lighter rigs but the reason I shouldn't is because the axle tubes are pressed into the differential and only spot welded in. Look at all the leverage those tubes have with the weight of the rig on them when you jack from the diff. The diff is not made to carry weight on that junction then add the leverage from the pressed in tubes and you could tweek it.
Good point, but pretty unlikely to see any damage as you're describing. If the axle can't support that weight, it probably shouldn't be under the van in the first place.
I agree in almost any situation, but loaded, like with a flat on a trip, lifting the heavy van at the diff could be risky.
For sure. Never on the side of a road, or anywhere off road. Only on a perfectly flat surface, like in a shop.
Chris Steuber
02 E350 7.3 (V4)
ujointoffroad.com
