Old 09-11-2012, 07:26 PM   #1
Dually Wheel Spacers
I know only a few of you have out there have duallies. I'm running BFG All Terrain TAs 235 85R 16s. With the stock Ford rims supplied on their cutaway chassis the rears are pretty close. I have 8200 pounds on my rear axle so I don't want to make a mistake. I was thinking of wheel spacers to get the tires apart and maybe let me air the duals down a bit on washboard dirt roads.
Are spacers safe?
Any recommended style or manufacturer?
Jim
Quigley 4x4 RV
Old 09-11-2012, 07:32 PM   #2
Re: Dually Wheel Spacers
I've used this guy:
http://www.wheeladapter.com/dually_spacers.php
His stuff is good and he knows all about axles, bolt patterns, etc.
Call him up and discuss what you need/want.
Old 09-11-2012, 09:18 PM   #3
DO NOT stick flat spacers between the duals. They will cause everything to loosen up with driving. I tried it for a while. Pretty much had to re-torque rear lugs with every other fill up.
Adapters, which bolt down and have their own studs are OK as far as staying put. Just keep in mind that pushing the wheel out too far could put you past the 102" limit.
To run 235's on my rear axle (I run 265s up front) and maintain good spacing, I went with a deeper-dished outer wheel set, i.e. more backspacing (which may actually be more negative backspacing on the outers.... I can never keep it straight....).
E- series dually rims are less dished than F-series. So just swappping to F-series dually wheels in the back should give you enough clearance for 235. However.... Les Schwab's used F-series inner steelies my last go around, and those caused rubbing between the tire and body when fully loaded and cornering hard. Had to switch back to E-series inner steelies (I broke both of my inner Alcoas so back to steelies for now).
My front rims and rear outer rims are matching 17" Ultra Goliaths. I actually went back to SRW front brake rotors so could run a wider 8" wide front rim, which is the recommended width for 265's.
Old 09-11-2012, 09:43 PM   #4
BIGVANS's Avatar
carringb, is it always raining at your house?
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 09-11-2012, 10:57 PM   #5
Think he wears a frog suit from time to time?
Old 09-12-2012, 02:00 AM   #6
From Halloween to July 4th, yes. It's actually pretty dry here in the summer months.
Old 09-12-2012, 07:36 AM   #7
Thanks guys.
Carringb, what year f series outers should I look for? Late 90's? 8 x 6.5 16?
Jim
Old 09-12-2012, 07:43 AM   #8
Looks like this is the one.
http://www.southwestwheel.com/store/p-1841-29578.aspx
Jim
Old 09-12-2012, 07:43 PM   #9
Yup that's the one
