Old 01-18-2019, 03:44 PM   #1
Feedback please...Mechanic asking for deposit for bulletproofing parts??
Would really appreciate the forums help.
The only local mechanic who's a preferred installer of BulletProofDiesel is asking for a deposit to cover the parts cost for the bulletproof, and engine parts upgrade = $8-10k.
parts list:
*rebuilt heads+studs+gaskets
*KC turbo 1.5
*injectors
*BPD EGR cooler
*BPD water pump
*Ford oil cooler
*STC+dummy plugs+standpipes
*SCT X4+custom tuning
*hoses+belts+clamps+misc that need replacing while the engines out
*BPD FICM (shop's choice...they only use preferred parts)
wanna do the BPD air-to-oil cooler, but the shop won't install.
Have never had this much work done to a vehicle, and wondered if this is normal?
Also, using the SMB map, and forum recommendations, I've contacted (via email):
* Quality Diesel in Auburn (can't do work because they don't have the engine removal tool);
* Devil Mountain - seems okay, except for the recent Yelp review
* Imler - no response yet
* Left Coast Diesel - no response yet
Any other shops to contact?
Regards.
Chris
Chris
2006 E350 EB 4x4 SMB: 6.0L-5R110-Atlas-D60-D60FF-yada-yada-yada
Old 01-18-2019, 04:03 PM   #2
Twoxentrix's Avatar
What are you having done?
Old 01-18-2019, 04:30 PM   #3
edited the original post...Thanks Twoxentrix!
Chris
Old 01-18-2019, 04:45 PM   #4
Pretty normal for a big project like that. Besides tying up cashflow for the shop, most of the parts have a re-stocking and shipping fee associated with returns, plus the shop would lose out of potential revenue if they blocked out a week for your upgrades but then you cancelled.
Old 01-18-2019, 05:40 PM   #5
Twoxentrix's Avatar
Your list looks pretty good. Its all about how much you're willing to spend, since the engine is out you may consider including some proactive maintenance items.
I did a lot of research & had some very qualified members here guide me - Below is the result of all the suggestions (you already have many of them mentioned):
*Heads - Studs - Gaskets
*Injectors
*STC- dummy plugs - standpipes
*Bullet proof FICM (6 stage unit)
*FICM harness replaced
*Injector Harness replaced
*Degas Bottle replaced & new cap
*Replace IC Boot
*New Turbo & Turbo tubes
*Turbo Oil lines replaced
*New BPD water pump
*New bullet proof EGR and valve
*Since low or irregular fuel pressure has a negative impact on both performance & lifters, its strongly suggested that the Fuel Pressure Regulator Spring be updated to the "Blue Spring"
*Install a Fuel filter/Water separator? at Minimum replace fuel filter
*Aluminum Radiator
*Replace fan clutch
*Coolant Filter installed
***On older vans, and since you'll have easy access with the engine out, you may consider replacing brake booster vacuum pump, and upgrade your alternator
Was also recommended (but I didnt do it at the time - Tech talked me out of it) to have Coolant swapped to a Silicate-Free ELC (ex: CAT EC-1)
(but I have my Coolant changed about every 10-13K mikes):
If your Engine currently runs on the hot side now, I would recommend installing the Mishimoto Low-Temp coolant Thermostat at the same time
Old 01-18-2019, 10:18 PM   #6
WhitH's Avatar
I’d say skip the BPD oil cooler. Not necessary for a van that has a reasonably clean coolant system with coolant filter from all I’ve heard. My diesel shop actually talked me out of it when I had a 6.0. Do get a coolant filter.
Sold 2005 E350 Chateau
Old 01-25-2019, 08:48 PM   #7
The latest version of the OEM oil cooler is sufficient and like Whit said, don't bother with the BPD cooler.
Old 01-25-2019, 10:16 PM   #8
Ditto on the oil cooler. It's a solution is search of a problem. I have a stage 1.5 KCturbo. It's a beast but your going to need some tuning to get rid of the lag. You might consider a stage 1 which is more of a drop-in with stock injectors. Or, save the $1400 and have them clean yours and add a stainless unison ring and perhaps a billet compressor wheel. That will save $600 or more.
The BPD 6 phase Ficm is nice for the redundancy but it's not really needed and there's not much empirical evidence that 53V or 58V is actually a performance increase. I'd stick with 4 phase 48V and you only need the power supply. The logic side rarely fails.
Engine is coming out. That's at least a 30hrs of labor if not more. Rate with parts looks reasonable to me. Lots of threads on bulletproofing in this forum with a quick search. Good luck!
2011 VW TDI Golf for hwy fun
Old 01-26-2019, 05:12 PM   #9
I can report so-so feedback with Left Coast Diesel. They seemed very knowledgeable on truck diesels, less than thrilled to work on van...especially “a sportsmobile”. Top mechanics(s) seemed skilled and knowledeable; but I think they often had young-ins finish the details. Which on three occasions had the details undone, in my case. I’m not very picky (because I struggle to find anyone in Bay Area who *wants* to work on my van)....but I stopped going to Left Coast.
Yovan is offline   Reply With Quote
Old 01-26-2019, 06:22 PM   #10
vandiesel's Avatar
I'd add that the BPD oil cooler actually creates a problem. I either have to re-plumb mine or replace it with stock as the shop put it in the winch box. It's also pretty bulky.
