Originally Posted by shenrie
Btw, which Quigley arms does your rig have? The tubular or the open u shaped ones? If you can’t answer that a quick pic of your arms and we can answer that for you.
SHENRIE thanks for that info on the suspension fab. The shop I used DID do fab but I get the impression he would just as soon spec components now... Up side of that is that he has told me that If I order something, they will install it. Since Im prone to doing my homework.
Yeah life gets busy and that cuts into fab work. My son and his friend have the skills to fab that but being both young fathers and working full time it is difficult to get their time redirected back to 4WD. Talented young men.
[QUOTE=arctictraveller;234884]So, you said the outcome of the Redhead was that the steering now behaves. Could you elaborate a bit on that? /QUOTE]
AT: As far as how the steering behaves, imagine this Before: Running over rough surfaces caused me to involuntarily shout out God Bless America while my arms bounced off the steering wheel in a manner not unlike Olive Oil's arms:
https://tenor.com/view/olive-gif-10016300
Now I can glide over rough patches in near calm- although its all relative especially in a 4wd van, right?
A vote of approval from me for the Redhead Steering Gear Box, plus excellent service from Redhead including quick and full refund for my core deposit- which the shop sent back for me. I didnt even have to break a nail!
Originally Posted by arctictraveller
Is your main concern that the van wanders? I'm fighting the same thing. How much caster do you currently have?
Yes WANDERS. On the way home from Ohio the other night I noted that on a Left hand curve, things feel solid. On a right hand curve (or say, switching lanes to the inside/right lane it seems necessary to fight a bit to maintain the curve.
I did not receive an alignment report with this alignment so I cannot give specs on how much caster I currently have.
Other things that can affect the issue can include worn spring bushings in the rear, worn ball joints or tie rod ends, and the tires themselves. In my case, tire pressure makes a large difference in how it drives, (even as little as 10psi). With my Duratracs, the higher the pressure, the better the steering, right up to a full 80psi. Unfortunately, running higher pressures makes the ride pretty harsh, so I'm considering replacing the tires, but I'm interested in hearing how the new steering box affected your steering.
Yes, I have rather stiff tires (the elsewhere ill-reviewed Toyo AT Open-Country, which I have been happy with). Running lower PSI does help for sure.
Probably have a year left on them tho mechanic suggested different tires. Also he kept mentioning that he thought that the AOR RIP shocks are a bit stiff.
Otherwise- All other suspension items have been gone over by two different shops with good reporting. **EXCEPT the rear spring bushings! Hmm I have leafs in back- so...this does not apply? Or does it? **
Shop owner says control arms show wear tho not to point of needing work. When I asked why should I need a steering box at 80 K miles his reply was that although he likes the Quigley system that a van chasis is not really made to run on a lift such as I haVE and and thats likely contributed to gear box breakdown- esp in light of the non-adjustable control arms.
I asked for a moderate tire suggestion and he said Mickey;s which got him a big scolding from me. I'm not made of money! From what he says his typical customer comes in with Very Large Truck and asks for Very Expensive Mods with few budget limitations. I do plan to buy an Aluminess rear tire mount tho so tire purchase inevitable.
Otherwise Not sure who all his 4x4 clients are except hes near Marysville and Honda plant = good wages. In WV they would be pipeliners- plus plenty of diesels there which keep the good local diesel shops way too busy for little ol lady customers to get a word in. Thus my V10 purchase.
Unfortunately she has a less than appealing ride on a long trip which is too bad since I was planning to drive West next year, perhaps South this winter. Having second thoughts now.
But I still dearly love HellBetty!
