Old 10-14-2013, 11:51 AM   #1
PSD 6.0 "Oil change required" on dash
Hello,
My 2009 e350 is equipped with the PSD engine. I just had the oil changed on 18.5k miles, and now, at just under 20k miles, the dash display shows "oil change required". Is this one of those generic service messages that pop up and given intervals, or has is the engine equipped with some sort of senor that has detected problems with the oil?
Thanks for the help.
DJM
djm68 is offline   Reply With Quote
Old 10-14-2013, 06:51 PM   #2
Pschitt's Avatar
Re: PSD 6.0 "Oil change required" on dash
No sensor on my 6.0 PSD. They probably didn't reset the mile counter when changing oil. You can do it yourself, it's indicated how to do in your owner manuel... ;-)
Old 10-14-2013, 10:01 PM   #3
Thanks for the note. I called my Ford service center and they indicated the same thing. Guess I should crack open that manual!
Cheers,
DJM
Woodstock
woodstock
Biggie
Berta
