Old 09-10-2013, 10:23 AM   #11
Re: Rear end noise !
Originally Posted by Stillvanin
Added the 2nd bottle and drove it about 300 miles. Seemed to help cut down on the chatter but it didn't stop it completely. I was told by a mechanic friend that the GM additive works the best so I'm thinking - start over drain the fluid and try the GM stuff. I'll keep you posted
BTW would an Eaton E- locker nip this problem ???
Unless you actually turn a lot, the lube won't get into the plates where it is needed. Driving thousands of miles on open highways may not get the plates properly lubricated. It isn't miles, it is feet while the LSD is slipping.
Old 05-10-2014, 04:53 AM   #12
Stillvanin's Avatar
So I'm STILL having this problem- and it's getting worse - to the point I don't trust it to drive it any farther than the local grocery store. I'm thinking of just starting over and installing an electric locker, I'm told this will replace the suspected bad clutches. I wanted to go with a locker of some sort anyway in the future as I plan to do a U-joint 4x4 conversion- just wanted to wait til after that ,but looks like I need to do it now. Anyone recommend a locker that would work in this situation ???
2005 SMB 5.4 EB 6" UJOINT conversion
I consider myself a half-assed perfectionist
Stillvanin is offline   Reply With Quote
Old 05-10-2014, 07:00 AM   #13
REF
REF's Avatar
Send a message via MSN to REF
I did a little research on this a few years back for our rig but never ended up changing things out as the stock limited slip is working fine, but will prob go with this if I need to replace it. Unless you are wanting/needing full locker front/rear, which is a little overkill for us, adding an eaton Detroit truetrac in the rear is a good way to go, this works best for seamless daily driving without putting added stress on the driveline, you can always add a locker in the front if you need/want to...
Talk to Chris about it....
http://www.eaton.com/Eaton/ProductsServ ... PCT_338418
Old 08-12-2014, 02:02 PM   #14
stiggs's Avatar
Send a message via ICQ to stiggs Send a message via AIM to stiggs
I had a similar noise years ago, added the lucus additive and it stopped. Have you gotten on some dirt checked your limited slip?
2000 Ford RB30 PH 2WD -- Eagle Rock California
stiggs is offline   Reply With Quote
Old 08-13-2014, 06:16 PM   #15
ANZAC's Avatar
I'm using the Ford limited slip additive. My axle builder said "add it drive it, if it makes noise, add more".
I think I have 4 or 5 bottles in mine, but I have a high capacity cover and have more gear oil.
This is a pretty common thing, don't overthink it. Just add more additive.
http://www.amazon.com/Ford-M-19546-A12- ... B003TPGELM
Sportsmobile-less.
