Old 07-22-2011, 11:44 AM   #1
CaveCreeker's Avatar
SCT computer tunes
2006 E350 6.0 engine is rebuilt with ARP head stud bolts, 175 swamps fuel injectors & aftermarket hi perf everything else.
Need competent computer tunes to make the beast go. Not enough power, who has the tunes?
also the clutch fan is screaming in the AZ heat, who has a pre-cut hood, who has front quarter panel cheek vents? I already have a nice custom cold air intake arrangement from Zylstra. Thank you for your responses.
CaveCreeker is offline   Reply With Quote
Old 07-22-2011, 12:36 PM   #2
Re: SCT computer tunes
Don't know much about tuning, but if you put it to stock 6.0L pickup that should give you a boost.
Old 07-22-2011, 01:48 PM   #3
SCT computer tunes
I would give Zylstra a shout. If you are in AZ, you might try these guys as well: http://www.bulletproofdiesel.com/
Current: 2014 15 Passenger V8
Former: 2009 SMB 4x4 6.0
Old 07-22-2011, 04:07 PM   #4
Have you installed a coolant filter yet?
I'm happy with my Diablo Predator. But I have a different motor.
Old 07-22-2011, 04:34 PM   #5
Yes - Coolant filtration system, (interesting to see casting sand in the filter even though the coolant has been flushed 4 times since I took ownership 11 09 & its a new radiator) 100% trans oil filtration, 100% engine oil filtration.
Hey all, bullet proof diesel sent me to Matt@gearheadautomotiveperformance.com
Old 07-23-2011, 06:16 AM   #6
viewtopic.php?f=13&t=6154
