Old 12-18-2016, 03:56 PM   #21
Originally Posted by shenrie View Post
If I was in a spot a quick shot of ether or wd40 has got friends cold diesels going in a pinch and I keep some onboard at all times. Just got to remember to try it before you kill the batteries.
Yep always carry a can of Ether in the tool box on your diesel they can be a life saver
"The problem with common sense is, its not that common." Mark Twain
1999 F-250SD XCab 4x4 5.4 170k
1998 E-350 LWB (Being converted now)
www.DirkMitchell.com
Dirk Mitchell is offline   Reply With Quote
Old 12-19-2016, 06:11 PM   #22
Only shoot it while the motor is turning over
hogasm is offline   Reply With Quote
Old 12-26-2016, 10:49 PM   #23
nemesisnight's Avatar
I am new to cold weather coming from AZ and now in Utah and also my 7.3 is the first diesel I have ever owned and only a few months at that, so not much experience to add. I started mine up tonight and it was 8 degrees out and it struggled a little bit but wasn't too bad. I run Archoil additive in my oil and gas, and I think I've noticed it running much smoother and starting much easier. Not sure if anyone else uses this but I think it was well worth the money and its obviously easy to do. I have 209k on my van.
nemesisnight is offline   Reply With Quote
Old 12-27-2016, 11:31 AM   #24
Bellpilot's Avatar
I have Kat's heater pads on my oil pan and on the transmission. If I am out and away from an 110v outlet I just fire up my Yamaha generator and plug the heaters in for about 20-30 min. and we are good to go. I also put in the Ford Diesel additive as well.
2010 E350 6.0 4x4 EB 50 SMB
99 Ford
dogredsurf
Agnes
ranchero
