Old 07-01-2017, 10:29 AM   #1
Flat Plate effeciency
This is for the guys with flat plate heat exchangers....
What kind of heat to you get from your hot water when the coolant is at max-temp and the engine is running? Do these transfer enough heat to use as a continuous hot water heater?
I'm trying to figure out a way to get the hot tub hot fast when boondocking. The electric hot tub pump only heat the rub ~2 degrees/hour
Old 07-01-2017, 02:00 PM   #2
Enough heat that I had to add a tempering valve. I've never measure the temp with the espar off and the engine running. I don't know why it wouldn't keep the temps up but I also have a circulation pump in the loop to increase coolant flows when the Espar is off.
Old 07-01-2017, 03:11 PM   #3
dig255's Avatar
When I bring mine, I use a Ecotemp L5 flash heater with a separate Shure Flow pump. Takes me about 4 hours to be at full operational temp 104°. Wouldn't want to idle for that long.
dig255 is offline   Reply With Quote
Old 07-08-2017, 11:20 AM   #4
Thanks guys. I didn't even think about a gas fired heater. I'm still not sure which way to go. My pump will do 15 GPM so I suspect the flat plate will cope better with the higher flow. Also the smaller space needs are nice.
Old 07-08-2017, 02:52 PM   #5
Bbasso's Avatar
Keep in mind the flow rate, if I have my valve open on my eccotemp it's half heat compared to not being able to touch the water on low pressure.
Rob.
Current:
And had three other E350s...
DADDOZR
REDOVAL
Margot
FCAshevlle
