Re: Suburban Propane Hot Water Heater on RB50
As far as I can tell, our tank and burner are a single unit (which also sounds logical). The installation requires cutting a fairly large hole in the side of the van and this single unit mounts to the hole...it includes a metal "wall between the tank and the burner so that the tank is "inside" the van and the burner is "outside" the wall so that you are not sucking oxygen from inside the van when the burner is lit. This "wall" sits about 2-3" from the outside skin of the van. So, the critical distance is not the length of the tank (which is perpendicular to the centerline of the van) but the length of the entire unit. But that might be the 17" or 19" you mention. (I would need to unload a lot of stuff to be able to measure ours.) Bottom line, the space you need must be measured from the outside of the van to the rear of the tank plus the thickness of the cabinet to protect it.
Hope this makes sense and helps...
Jack
'01 Ford EB50p Quigley 4WD
