Old 08-25-2019, 01:32 PM   #1
jeff00seattle's Avatar
Question Bottle Jack and accessories
Hi
I started the following thread 3 years ago: Jack Recommendations
After reading this threads multiple suggestions, I am finally getting around to actually honestly seriously purchasing a bottle jack. Need feedback before I purchase.
I have been looking a SafeJacks, since that was the most recommended site.
Specifically, I am considering purchasing this pricy kit and base plate $218:
Starter Bottle Jack Recovery Kit with 6 ton bottle jack
Bottle Jack - 4 to 6 ton -- Enough to lift fully loaded Sportsmobile Van:
The following bottle jack is provided by this kit, however, are there better ones in quality and price?:
Omega 6 Ton Bottle Jack
Jack Accessories
Since the stock jack that is provided by Ford E250 Sportsmobile does not provide any jack accessories as are provided by the SafeJack Kit (Flat Jack Pad, Universal Pad, Jack Extension), then would anyone recommend any of these accessories?
3 Piece Starter Pack
Base Plate -- Assure offroad tire changes:
Universal Bottle Jack Base
Thank you
Appreciate this forum's feedback
Jeff in Seattle
Jeff in Seattle
2001 Ford E-250 RB50
jeff00seattle is offline   Reply With Quote
Old 08-25-2019, 04:26 PM   #2
Depends on your style of outdoorsy. I'm still mostly a pavement pounder so the factory jack with a 2 ton floor jack, a few wood blocks and campsite levelers will get me out of anything I'd be up against. YMMV
Peace, Regis
2011 Express 1500
I'm a camper not a glamper
regis101 is offline   Reply With Quote
Old 08-25-2019, 06:12 PM   #3
BrianW's Avatar
Is your van 4x4, lifted, or otherwise higher than standard height?
Old 08-25-2019, 09:23 PM   #4
I lift My e250 with 33s and a 4in lift using the stock jack and a wood block. I just had all 4 wheels off the ground on a dirt road with no problems. A hydraulic jack would probably pump up easier than the stock Jack goes up, but the stocker does the job, and it's probably lighter than most alternatives.
Old 08-25-2019, 09:35 PM   #5
larrie's Avatar
My 6 ton bottle jack came from the auto parts store. Then I pieced a kit together from the individual components from Safe Jack. The carrying bag came from Home Depot.
Initial Safe Jack components
Screw collar
3” extension
6” extension
Flat jack pad
3” universal lift pad - this one fits around the rear axel but not the front.
Added these later.
5” universal lift pad - needed this to fit around the front TTB arm on the Agile Off Road 4x4 upgrade.
Universal bottle jack base plate
Their stuff is very well made.
Larrie
Old 08-25-2019, 10:43 PM   #6
1der's Avatar
It is seriously really hard to beat this set up for our rigs:
http://www.sportsmobileforum.com/for...ter-19777.html
How much do you want to carry?
Old 08-26-2019, 12:35 PM   #7
No, the Sportsmobile PopTop is set upon a standard Ford E 250 van (not 4x4 nor lifted).
Thanks for your reply.
Jeff in Seattle
Old 08-26-2019, 12:45 PM   #8
My focus is to be self-sufficient when stuck in rutty and possible soft dirt roads.
I would prefer to carry the minimal amount but not regretful of not carrying enough.
Are you referring to this jack: Off Road Scissor Jack w/ Axle & Frame Adaptor
Is this worth the price of $340?
Jeff in Seattle
Old 08-26-2019, 01:06 PM   #9
Screw collar
3” extension
6” extension
Flat jack pad
Added these later.
I am very curious of your final jack configuration.
  1. What is your 6 ton bottle jack and why did you not buy Safe Jack's Omega 6 Ton Bottle Jack?
  2. Have you found any your purchased jack accessories unnecessary?
  3. Would you recommend getting both 6 Ton 3" Universal Lift Pad and 6 Ton 5" Universal Lift Pad
Jeff in Seattle
Old 08-26-2019, 01:15 PM   #10
Thanks for your response.
  1. So from your experience, you are comfortable for off-road tire changes using the stock 2 ton jack on a woodblock? Several contributors to this forum recommended replacing it with a stronger (3 to 6 ton) bottle jack for a fully loaded SM with gear and supplies.
  2. Recommend any accessories? Universal Lift Pad, Flat Pad, or Extender. For example, Safe Jack jack accessories Pack
Jeff in Seattle
Tags
jack
