Old 06-18-2018, 04:40 PM   #1
dokaman's Avatar
New under van propane tank?
Hello SMBers,
I am in the process of building an Econoline van and I have run into an issue. I installed a flip down door from SMB on the drivers side for a permanent propane tank. Now that I have the nice door installed and cut a big hole in the side of the van... I am not able to locate a new tank for it. Do any of you have a lead on a tank? I am looking for a 10 Gallon tank with the fitting pointing straight out, not angled down.
New is preferred, however a used one that is good enough to refurbish is ok as well.
Thanks for any advice.
Justin
2001 Van Haus E350 EB 7.3L Quadvan 4X4
1999 Sportsmobile E150 - SOLD
2002 Sportsmobile RB50 7.3L 4X4 - SOLD
dokaman is offline   Reply With Quote
Old 06-18-2018, 04:58 PM   #2
rallypanam's Avatar
https://www.pplmotorhomes.com/parts/...ntal-motorhome
Old 06-18-2018, 05:41 PM   #3
shenrie's Avatar
See lots of people recommend these guys too.
Propane tank | GoWesty Search Results
Old 06-19-2018, 06:51 AM   #4
The links above are all for Manchester brand tanks. They make them 2 ways...RV type and van type.
On the RV type the fittings are somewhat on the side of the tank (below the centerline) to be exposed when you open the flap door. The van style have the fittings horizontal but near the bottom of the tank for vans. The GoWesty tanks are van style.
Old 06-19-2018, 05:36 PM   #5
dhally's Avatar
Smb west sells theirs
2009 E250 RB 5.4L "SilVan"
Old 08-07-2018, 04:48 PM   #6
ScotFree's Avatar
Propane tank
Any luck with you propane tank search? I want to install the same 7.9# tank SMB uses. But can't find out what the brand and model number is. Do you know? I would buy new off the web if I had that info. It seems it is a very tight fit and other tanks on the market may not work.
'08 E350 SD EB Cargo 6.0
Bought New 5/2010
Quad Van 4x4
Rudimentary DIY Camper
ScotFree is offline   Reply With Quote
Old 08-12-2018, 11:36 PM   #7
dhally's Avatar
I found SMB West to have the best price, and their tank fits without modifications.
Old 08-12-2018, 11:57 PM   #8
dokaman's Avatar
I am planning to buy the tank SMB West sells. It is not on the website so send an email or call them.
Justin
Old 08-12-2018, 11:57 PM   #9
dokaman's Avatar
Thanks for all of the other ideas as well!!!
Justin
Old 08-13-2018, 07:42 AM   #10
Hi. Sportsmobile West install a Manchester 6814, 8 gallon propane tank. They are on Amazon.
Cheers Doug
2008 Yellow Ford E350 6.0 diesel eb50 4x4, Front E Locker, Asheville Eng Rebuil 20th @ 261miles, ARP Studds, 200amp Alternator, Performance Aluminium Radiator, OnBoardAir, RoadmasterActiveSuspension, Front & Rear Aluminess with Spare Tire Carrier, Aluminess Roof Rack, Titan Aft 30gallon Fuel Tank.
Sheriffdoug is offline   Reply With Quote
