Old 10-15-2016, 07:58 AM   #1
penthouse concern
Has anyone experienced a mark akin to the attached photos on the top of their penthouse. Any thoughts on what I should apply to the scar to prevent expansion. I have no clue what caused the blemish.
Thanks
surfmobile is offline   Reply With Quote
Old 10-15-2016, 10:42 AM   #2
Welcome to the world of stress cracks.
To stop them from spreading you will need to drill a small hole through the gel coat at the end of each spider. The hole will stop the spider from crawling farther. It will not fix the issue which was created from the transfer of load on too small of an area.
To repair them properly you would need to grind out the spider until the gel has a good bond to the glass all around. Then either fill with glass then gel over or you might be lucky and the glass is not compromised and you will only need to re gel.
This is a great video on stress crack repairs
hogasm is offline   Reply With Quote
Old 10-16-2016, 04:23 PM   #3
Thanks Hogasm. Very helpful. Guess I better get on this one.
Old 10-16-2016, 07:48 PM   #4
TexGX's Avatar
I would raptor line after repair.
TexGX
TexGX
2003 7.3PSD RB50 Quigley (The Yeti)
viewtopic.php?f=10&t=13220
2006 Casita (Makes it a three bedroom 1 and 1/2 bath)
TexGX is offline   Reply With Quote
Old 10-16-2016, 07:57 PM   #5
TexGX
The message you have entered is too short. Please lengthen your message to at least 10 characters.
Old 10-16-2016, 08:39 PM   #6
Surfmobile how thick is your top at the spider?
Agnes
alta825
Guster
Salmon
