Old 08-03-2012, 02:06 PM   #1
question on brakes
have a 2002 ford E-350 EB... what are the best brakes and rotors for this vehicle.. rangerrick2
rangerrick2 is offline   Reply With Quote
Old 08-03-2012, 03:46 PM   #2
ANZAC's Avatar
Re: question on brakes
Is it a Quigley 4x4 conversion, if so be aware that the front rotors can't be bought over the counter, they need to be machine to clear the ABS sensor. Contact Tiger at Quigley for more info (and they sell the rotors).
On my old van I had Hawk LTS pads, and some cryo-treated rotors (brand escapes me right now).
Sportsmobile-less.
Old 08-03-2012, 04:07 PM   #3
PowerSlot?
Old 08-03-2012, 07:33 PM   #4
I'm running Frozen Rotors from:
http://www.frozenrotors.com/
and Performance Friction Z-Rated pads from the same place.
Definitely better than what came stock on the 05 F350 Axle.
Old 08-03-2012, 08:48 PM   #5
ANZAC's Avatar
PowerSlot?
Yeah PowerSlot cryo treated.
Sportsmobile-less.
Old 08-04-2012, 12:26 PM   #6
Brakeman super brakes for heavy equipment is what I switched to. Slightly better stopping during normal driving but a huge difference in long power stopping. Before the switched I almost got caught up in a crash coming down a hill when a guy turned to miss another vehicle. The brakes faded out and I couldn't stop in the end. Now I have much better braking for long distance high speed stopping. I also switched to the high temp brake fluid they sell.
Old 08-04-2012, 02:30 PM   #7
BIGVANS's Avatar
Remember to be careful when changing to any “High Temp” brake fluid. Most of them are Silicone based and NOT hygroscopic (aka hydroscopic) they don’t absorb water so you end up with rust pits in your calipers over time. Stick with DOT3 and/or DOT4 and stay away from DOT5 unless you flush the brake system after every race ….. I mean trip.
2003 Ford E-350SD 4x4
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
Old 08-04-2012, 03:44 PM   #8
I've silicone brake fluid for years with no water issues. Water just doesn't get into the brake system. DOT 3/4 fluid pulls water out of the air, DOT 5 does not.
That said, DOT 5 is not compatible with most ABS systems. It is too viscous and will not let the ABS work properly.
Don't use DOT 5 in any vehicle with ABS brakes, including my van.
Love DOT 5 in my motorcycle brake systems.
Old 08-04-2012, 06:09 PM   #9
Well I hope they know what they're talking about or there will be lots of ambulance and fire equipment around having problems including my van Good point though.
Old 08-04-2012, 09:58 PM   #10
BIGVANS's Avatar
Me too ... MOTUL!
http://www.motul.com/us/en-US/products/77?f[application]=144&f[range]=21
(A bit pricey)
V10 / 4R100 / NV271
Reunel Rear Bumper
On And On ...
