Thanks! I'm really happy with how it came out and how everything mounts up there. I ended up using smittybilt gutter mounts and have t slot going across to support at the mounts. If you are buying hardware I found t-nutz to be the cheapest for the nuts and some of the mending plates. I bought 316ss button head screws through McMaster Carr to mount everything. PM if you go this route and I can give you some tips to help figure out what you need.
I used 1/8 aluminum. 2" width for the face and 4" width for the tops and bottoms. 45's at 3-1/2 apart, mark the tops to cut the trapezoid, weld together, then drill your holes for the t-slot nuts. If you need more details hit me up on a pm
Great, thanks for the details. Will do if I hit a snag.
