Old 03-14-2017, 10:22 PM   #1
Rust
I just noticed the paint bubbling up from rust on my 2 1/2 year old Sprinter. It was a small spot near the water inlet. I pulled the fitting off and found considerable rust. I pulled off the electric inlet and it was even worse. Lots of paint had gone away. Turns out every hole Sportsmobile cut was rusting away. I sanded the rust down to bare metal, primed and painted. I'm so glad I found it when I did. I don't know why Sportsmobile didn't prime the cuts.
Kelp is offline   Reply With Quote
Old 03-15-2017, 07:23 AM   #2
That's a serious bummer. I'd be pissed but honestly it doesn't surprise me that SMB doesn't take the time. I've seen lots of corners cut in their work.
Do you live right on the ocean or inland?
Old 03-15-2017, 09:25 AM   #3
I live in So Cal and not close enough to the beach to make a difference.
Old 03-15-2017, 10:56 AM   #4
bemerritt's Avatar
I would be so mad with a vehicle that new. Did you send them pictures?
bemerritt is offline   Reply With Quote
Old 03-15-2017, 11:26 AM   #5
I did send them an email and did not receive a response
Old 03-15-2017, 11:33 AM   #6
I'm curious why I haven't seen this repotted by others owners. It wouldn't take much longer for major rot.
Old 03-15-2017, 11:50 AM   #7
It's pretty sad they couldn't treat the edges of the raw metal left behind. Everyone knows that rust will quickly follow. It's good you found it before it got worse.
Old 03-15-2017, 02:44 PM   #8
LenS's Avatar
It would seem that if there were sealer or a gasket in the joint water would not get in. Were the fittings just bolted on with nothing sealing the fitting to painted steel joint?
Len & Joanne
The Green TARDIS
Old 03-15-2017, 09:10 PM   #9
Stillvanin's Avatar
I'm not surprised. That's the kind of attention to detail SMB fails to do. I don't get it, it's an obvious future rust spot that takes minimal time and effort to do correctly- mind boggling.
2005 SMB 5.4 EB 6" UJOINT conversion
I consider myself a half-assed perfectionist
Stillvanin is offline   Reply With Quote
Old 03-15-2017, 09:50 PM   #10
BVerhulst's Avatar
Yikes. I'll be investigating the cuts in my van soon...
Brian
2009 E-350 Lopes 55
BVerhulst is offline   Reply With Quote
